Sponsored by:
Sponsored by: CARiD
Phantom Shut Down Issue
Old Sep 11, 2009 | 05:16 PM
Madrican's Avatar
I am having a shut down issue with my Evo X MR 08. My Evo has done this about 4 times in the past 6 months since I owned the vehicle(stock exhaust).
Once in a blue moon, when I start the car the rpms will go around 400-600 stay there for about 20 secs or so then the car will shut down. When I am like wtf and restart the car everything is fine..
I took the vehicle in to find out what is happening about a month ago. According to the local mits dealer my Evo was the 3rd one in for this problem. They said it was a easy fix (only had to update my stock map). Now a month later the same issue again, but this time I have a HFC and exhaust. And lord behold metal on metal sounds coming out from my tail pipes when it happens. !!!
I am taking the car back to the dealer to find out what is happening. What I was wondering is if someone here has an idea what is happening or had this experience too.
Old Sep 11, 2009 | 08:22 PM
Madrican's Avatar
Update: I called the dealer they won't see my car until Monday.
I don't understand what is happening. The main reason I dont understand is because there is no service soon or anything when this happens. I should have stay with my 03 VIII! I just hope the dealer doesn't see any evidence of my cobb tuning once I uninstall it.
Old Sep 14, 2009 | 06:33 PM
shivaswrath's Avatar
i suspect it's a vacuum hose of some sort. . .
Old Sep 14, 2009 | 11:31 PM
hoobavent's Avatar
I just had this exact problem this afternoon. It happened to my Evo X twice. I start the car the tach needle jumps around below 2k and back up to 2k again then shuts down. I restarted it then everything's fine. Same thing happened again the 2nd and last time. I wonder what's causing this coz this is a brand new X and I dont see any reason why this would happen. I'll observe till this weekend and if it happens again Ill take it back to the dealer.
Old Sep 15, 2009 | 12:02 AM
jondimellow's Avatar
try seeing if your stock air intake box is hooked up correctly (bottom)
Old Sep 15, 2009 | 12:04 PM
Sschmuve1's Avatar
I hope its not a crankshaft position sensor problem that plagued VQ Nissans. Those would shut down too unexpectedly.
Old Sep 17, 2009 | 12:11 PM
Madrican's Avatar
From what someone told me I believe it is vapor lock. What was the temps outside when this happen to you?
Old Sep 17, 2009 | 10:40 PM
hoobavent's Avatar
It wasnt hot nor cold that day when it happened since the weather was fair. Vapor lock is possible though.
