Sponsored by:
Sponsored by: CARiD
Strange "Service Engine Soon" light-why?
Old Sep 23, 2009 | 01:17 PM
StevX's Avatar
08 GSR
21,000 miles
No mods, besides a conservative Ecutek tune done about 13 months ago
No track use, 0 launches, no autocross use
I was pulling out of a parking lot today and slowly driving towards the street in first gear. RPMs rose to about 5 grand under light throttle and then fell as I approached the red-light intersection to the street. As I pulled out into the street and began accelerating in first gear (again light throttle), the car pulled back (the car would not accelerate) and the "Service Engine Soon" light came on. I immediately pulled into a gas station, and turned the car off. Waited a few minutes, turned the car on and the service engine soon light is still lit. The car seems to drive fine, although I have stayed out of boost. The temp gauge appeared normal. Any ideas?
I'm leary of taking the car to a dealer due to the tune.
Old Sep 23, 2009 | 01:32 PM
atombomb33's Avatar
EvoM Community Team
Could be a number of things. Try to find your local AutoZone and have them pull the code. Then post that up and we can help better
Old Sep 23, 2009 | 01:39 PM
Drew84's Avatar
Flux Capacitor failed. See it all the time.
Old Sep 23, 2009 | 02:24 PM
mlomker's Avatar
Pull the code or disconnect the negative battery cable for a while to get rid of the CEL. If it were something serious then it'll come back on again.
Old Sep 23, 2009 | 02:53 PM
StevX's Avatar
Had the code pulled at autozone. It's P1238 - "Manufacturer control fuel air metering" is what came up on the scanner.
When turned the car back on after getting the scan, the Service Engine Soon light was gone and the car seemed to drive normal on the way home.
Thoughts?
Old Sep 23, 2009 | 03:26 PM
raytrix's Avatar
Narrowband messed up? Or cat going out?
Old Sep 23, 2009 | 03:43 PM
JJsEvo8's Avatar
Try cleaning your MAF sensor (there is a spray for this) and check your air filter.
Old Sep 23, 2009 | 04:21 PM
blk-majik's Avatar
In EVO world, P1238 = Mass airflow sensor plausibility (torque monitor). I'm not sure how that differs from P1235, but P1235 (also MAF plausibility) can be cause by overboosting or a bad MAF. Tunes that increase boost can trigger it at peak boost (around 3500rpm).
Old Sep 23, 2009 | 06:53 PM
StevX's Avatar
Hmm... peak boost was not raised in my Ecutek tune, and I replaced the air filter less than 3000 miles ago. Perhaps a dirty MAF Sensor?
If I end up taking it to the dealer, will the aftermarket tune be blatantly obvious when they try to pull the code, or is that something they would discover only if they were looking for it?
Old Sep 23, 2009 | 07:25 PM
mlomker's Avatar
Yup, and some dealers look for it. Nothing is for certain if you modify the car...that's just how it is.
That being said, you'd be better off having your own Tactrix cable/laptop so that you can change your flash when you need to. A quick search on your error code on here brought up some interesting threads...one of them bashed mail-in tunes as being inadequate...I'd talk to your tuner.
Old Sep 23, 2009 | 07:45 PM
buchnerj's Avatar
Avoid the dealership at all times. Go to the local parts store and DIY at all costs. Most dealerships will find something that can void your warranty the second they pop your hood. Clean the MAF sensor and see if it comes back, if you cleared it and it didn't come back after a couple starts and little drives you should be fine, could have been a piece of debris that made it through the filter that fouled it up. Mine used to come on when i was under WOT, cleaned it with the CRC spray, no problem anymore... my 2c
Old Sep 23, 2009 | 08:27 PM
Brokenevo's Avatar
just go to service its under warranty
Old Sep 23, 2009 | 09:10 PM
StevX's Avatar
Thanks for the replies.
Another thread claimed the code is a result of high partial throttle boost (which seems to fit my circumstances).
FWIW, my tune was not a mail-in tune.
So in other words, unless the dealer was looking for a tune they would not notice it?
Old Sep 23, 2009 | 09:24 PM
Brokenevo's Avatar
you are correct, my good buddy is a diamond tech for mitsu, they wont know it was ecu tuned unless they really look into it. I just asked him this question too earlier. I guess TTP in Florida is locking the ECU's back up after they tune them too.
Old Nov 1, 2009 | 10:41 PM
evo_RS's Avatar
Hi guys, i have the same problem, today I install the injen UICP, injen intake pipe and the Gredddy EBC, i start the engine after i hook up everything and the Service Soon Light came out, what could be the problem?
I clean the MAF with a CRC contact cleaner from the inside because was dirty, did i mess up the MAF with the conctact cleaner? i did that before and didn't have any issues.
Can someone help me
Mod are:
Nesei LICP
Still have the stock ECU without a flash
Apexi Intake
thanks
