Sponsored by:
Sponsored by: CARiD
Smell inside cabin???
Old Nov 8, 2009 | 03:40 PM
jrsimon27's Avatar
hi friends lately i have noticed a smell coming inside the car through the a/c vents but it only happens when iam using the air conditioning and when i race my car when daily driving it normal nothing smells only when i race it or do spirited driving??
any thoughts on this?
thanks
Old Nov 8, 2009 | 03:50 PM
mike100's Avatar
I have the same problem..it's the evaporator drain clogged with dirt and dust and keeps a pool of water in your ac box. You can open the windows and run the heater for about 1/2 an hour to dry it all out and hopefully kill the mildew and mold that stinks. If you spray a little lysol into the fresh air intake on the cowl by the windshield wipers while it is running, it will vent thru and help kill the odor too.
make sure the vent is set to outside air and you should pop out the cabin filter for a quick look at that too (behind glove box).
Old Nov 8, 2009 | 03:59 PM
jrsimon27's Avatar
ok ill try this the thing is that its like a burning smell and my car is completly stock but i will try this to if it works thanks
Old Feb 19, 2010 | 02:54 PM
jrsimon27's Avatar
ok after several days of looking the car with a mitsutech he found that the smell that comes from the back of my car is not under seat.
it has to do with the battery and a small tube that comes out of it,this tube goes through the car and goes under the car its position on top of the exhaust so when we looked at the stock exhaust it has some white spots on it and he says thats the acid coming from the battery so when this acid hits the exhaust it produces the wierd smell and it get inside the cabin via the vents on the trunk.
so we will see how we re-route the tube so the acid doesnt fall on the exhaust.
__________________
Old Feb 19, 2010 | 03:20 PM
smoothevo's Avatar
Damn that's crazy - doesn't sound to safe.
Old Feb 19, 2010 | 03:33 PM
Brokenevo's Avatar
the acid should not be coming out of the battery plain and simple. Replace batter ASAP lol
user 38475849
Aug 27, 2016 05:21 PM
EngRWW33
Lancer Troubleshooting
10
Mar 3, 2010 08:19 PM
Hashfather
Mar 1, 2006 10:04 AM
deekay247
25
Jun 13, 2005 10:53 PM
ltwayner
Jan 25, 2005 09:06 PM
