Sponsored by:
Sponsored by: CARiD
WTH is this?
Old Jan 1, 2010 | 10:45 PM
ak47m203's Avatar
WTH is this?
Im just looking around when I open it it is just hanging around there. There is a sticky at the back so it should be sticking on something. Is it a black box? Check yours if you have this too.
Old Jan 1, 2010 | 10:54 PM
SpeedI2acerX's Avatar
Looks like it broke off from somewhere. Could explain where the rattles coming from lol.
Old Jan 1, 2010 | 10:55 PM
Brokenevo's Avatar
should say what it is on the other side?
Old Jan 2, 2010 | 05:14 AM
ak47m203's Avatar
im thinking lo jack.
Old Jan 2, 2010 | 07:20 AM
scottatyamaha's Avatar
Curious...never seen that up there.
Old Jan 2, 2010 | 07:25 AM
Frankiago's Avatar
Pretty sure this is the standard location for installing LoJack, so I'm thinkin you're thinkin on the right track.
Old Jan 2, 2010 | 08:03 AM
Did you buy your car used or parents, girlfriend keeping a tight tab on you?
Old Jan 2, 2010 | 08:15 AM
Xtremist's Avatar
Never seen that in my X!
Old Jan 2, 2010 | 08:23 AM
buchnerj's Avatar
Post up the barcode or any other markings on it. Possibly a GPS locator, or some form of an alarm system. Better hurry before the assassins track you down.
Old Jan 2, 2010 | 09:26 AM
hotdog's Avatar
You're missing a pedal.
Zing! Zing zing zing.
I'd guess some sort of Lojack thing, but I have no clue.
Old Jan 2, 2010 | 09:43 AM
silver9mr's Avatar
yes its deffiently the low jack box.. when i got mine serviced the guy showed me exactly what it looks like and thats what it was
Old Jan 2, 2010 | 10:15 AM
Bighec's Avatar
That's not a very discreet and secret place for a lo-jack transmitter!!!
Old Jan 4, 2010 | 09:26 AM
popdakebin's Avatar
lol. I think it's time to move the location of that gizmo. Is it connected to anything? I would hide it behind the headunit or in the dash somewhere.
Old Jan 4, 2010 | 09:47 AM
solipsism's Avatar
Whoever installed your security/command start/gps put it there. its probably loose so you could access your fusebox. It could have been mounted better obviously. Part of my compustar is located there. My gps/sim card is located underneath the aftermarket deck behind my dashkit.
Just remove the fusebox door and then 3 screws on the panel that surrounds your knee airbag and fuse box door, then pull it off. Get a couple ty-raps and mount it in the air loosely so its not too tight but you can easily move it around to access your fusebox but the module isn't really rubbing against anything (so its not hard to access the fusebox again). Mine is kind of floating in front of the fusebox but easily movable and not touching anything so it doesn't vibrate.
It probably runs to an antenna located on the upper right portion of your windshield. Its probably also tied into the fusebox (im trying to go by memory). So you may not be able to move it too far (center of dash) because of wiring.
Old Jan 6, 2010 | 07:10 AM
tonyboy's Avatar
i have a lo jack and i'm pretty sure that is not the lo jack device (well compared to mine and what was installed in mine maybe different lo jack package?)...by looking at how huge that compared to my lo jack device, what package did you guys get? i got the EW..i was thinking that was like a bluetooth or keyless entry device maybe?
