Sponsored by:
Sponsored by: CARiD
Buschur Racing's major EVOX build
Old Jan 14, 2010 | 02:41 PM
mlomker's Avatar
Originally Posted by Spoonie
Very nice but illegal as hell on public roads.
I think half of the aftermarket parts that I've purchased said "off road use only" somewhere on the documentation. I didn't install them, of course.
Old Jan 14, 2010 | 02:48 PM
David Buschur's Avatar
First engine, we are guessing as of right now, failed because of the faulty fuel pump relays, it's about all that makes sense and the engine has clearly detonated, both of the cars here actually. Something else I forgot to cover in the first post, all of my exhaust valves were bent from hitting the pistons. The Cosworth cams we are going to highly recommend either sticking with the STOCK revlimiter OR adding upgraded springs to the head from now on. We had to raise the rev limiter to 8500 to finish the quarter mile and I'd guess the added RPM was too much for the stock spring.
As for the street car.........if you want to get technical about an offroad pipe, replacing the cat with ANY high flow cat or offroad pipe is illegal in all 50 states until the car has over 100,000 miles on it. I don't give two ****s about the cat or whether or not having one makes this a street car or not. The arguement of what is and isn't a street car has been beat to death. It is absolutely a street car, so we are clear.
Old Jan 14, 2010 | 03:07 PM
h22gordo's Avatar
Very nice work David.
Was your engine block sleeved?
Old Jan 14, 2010 | 04:14 PM
jo evo's Avatar
Looks very sick work Dave,i notice that you dont use the o-rings on the block or the head.Any change on mind about the orings?
Old Jan 14, 2010 | 05:02 PM
1d10t's Avatar
Totally sucks about that relay!
Was also wondering if the block was sleeved. Sorry to hear about the detonation
Old Jan 14, 2010 | 06:40 PM
Evo a Mula's Avatar
cant wait to see this car in the 9s good luck
Old Jan 15, 2010 | 06:49 AM
MR. Tim's Avatar
Looks good. Can't wait to see results.
Old Jan 15, 2010 | 07:01 AM
Block is stock no sleeves. We've got three of these apart and all three have held up good on the stock engines, even though they've been pushed far enough to detonate and damage them. We will start sleeving blocks when we see a need for it, so far so good.
I chose not to o-ring the block or head on the EVOX to see how it will do without it. So far stock gasket, stock head bolts have held over 30 psi on pump gas without any problems.
We don't do things, offering parts or extra work just to add profit to what we do. That's not how this shop is run.
Old Jan 15, 2010 | 07:02 AM
Domolution's Avatar
Damn, those pictures are just beautiful!
That build is going to be epic!!!!!
Can't wait for the finish!
Old Jan 15, 2010 | 07:10 AM
Hiboost's Avatar
More and more I'm considering just adding in a relay that gets triggered by the stock pump power so that there will always be 14v to the fuel pump. That way if the stock relay fails partially it will still be fine. If the new relay fails the entire fuel pump shuts down with minimal risk to the engine.
It will be incredible to see this Evo X car run 9's in streetable form.
Old Jan 15, 2010 | 08:38 AM
blk-majik's Avatar
So the fried plugs that you've seen twice, and that several other have seen.... you believe it's not a problem with the plugs themselves, but with the fuel pump and/or fuel pump relay not being able to deliver fuel in the top end, thus causing an unsafe lean condition that would fry most any plugs? There have been lots of reports of fuel starvation during track events that were attributed to sloshing... maybe it's a bit of this as well?
You swapped to a more capable pump and went with a new relay. Is this something you'd suggest anyone wanting to make more power consider? Whats the part # for the relay you're using now?
Do you see any value in this fuel relay test? https://www.evolutionm.net/forums/ev...ay-1-test.html
Old Jan 15, 2010 | 09:51 AM
s.e.a.n.'s Avatar
Nice build up.
Old Jan 15, 2010 | 09:59 AM
UT_EvoX's Avatar
Not to crud up Buschur's thread, but that wouldn't be a good idea at all... you would still have fuel pressure for a split second as the fuel pump cut out, and your fuel injection system wouldn't know the pump was shut off, so the injectors would continue to pulse. This would lead to a VERY lean burn situation and would most definitely lead to some massive detonation.
Now if it cut off the MFI relay as well, you'd be good
Old Jan 15, 2010 | 10:11 AM
I have not changed to the new Mitsu relay yet, we ordered them but they have no come in yet. I'll assume the new part will not cause any problems. The car does have out double pumper in it now.
Old Jan 15, 2010 | 11:07 AM
Clark_Kent's Avatar
Great work David. I'm excited to finally see a hardcore build from Buschur Racing. Please keep us updated.
