Sponsored by:
Sponsored by: CARiD
Windshield Washer Nozzle Adjustment?
Old Mar 24, 2010 | 11:04 PM
MacGyverGT's Avatar
Does anyone know if the washer spray nozzles in the hood are adjustable? Mine seem to spray in the lower half of the windshield, and if I could angle them up a bit it would help.
I googled the matter and the common theme (not Mitsu/Evo specific) is using a pin or paperclip to move the nozzle, but ours looks more like a flathead opening. I didn't touch it for fear of snapping something off.
Anyone?
Old Mar 25, 2010 | 12:55 AM
Evo4Emperor's Avatar
bump.. im in the same boat... its almost like i have to time it perfectly so that the washer fluid spreads upward instead of being blocked by the wipers
Old Mar 25, 2010 | 08:09 AM
lemmysports2's Avatar
i stuck a safety pin in the nozzles on my VIII and using the pin for leverage point them in the proper direction, they were shooting over the roof.. the X's are probably about the same
Old Mar 25, 2010 | 08:27 AM
ikt's Avatar
ikt
same here! I'm not sure they are adjustable, i tried to adjust them like i would any others, but they look fixed flat and wide
Old Jul 26, 2012 | 06:33 AM
an2ny's Avatar
BUMP to this old thread.
I am having a similar issue. The nozzle on the passenger side keeps popping up, I push it in and it keeps coming up, making the nozzle spray all over the side. I will be taking the inner lining of the hood apart soon to see if there is a solution.
Anyone else with this problem?
Old Jul 26, 2012 | 10:07 AM
m0nkie's Avatar
nothing like spraying water right into the passenger's face when the window's down
Old Jul 26, 2012 | 11:48 AM
turborat's Avatar
I use to stick a piece of fiberglass under the nozzle on my VIII. Even the most minute angle variance can change the spray trajectory by a lot.
4G63_EVO
Apr 14, 2017 01:36 PM
jrsimon27
Jul 12, 2016 06:36 AM
peanutcracker1
Aug 11, 2014 06:44 AM
ikt
Evo X How Tos / Installations
May 12, 2014 02:23 PM
Willie Dynamite
Apr 6, 2013 06:11 PM
