Broken Fuel Pump Bolt...
did you drop the hammer on it? how the heck did you do that LOL.. anyway.. Im thinking if you can put something similar...is the other piece of the bolt still in there??? perhaps drilling it out???? hope you fix it in time..
It didn't matter, its been weeks and no issues. If you're really concerned, you could just shoot a self tapping sheet metal screw through the bolt hole.
Don't use a self tapping screw, it could cause a leak since the metal plate you're screwing into doesn't actually make a contact seal against the fuel tank. You would be better off running a bolt from inside the fuel tank and running a nut on the outside. Afterwards maybe seal around the bolt with some silicone or something else that will hold up.
I broke two off recently, got to get em fixed ASAP. I'm thinking of doing a through bolt with jbweld on the bolt head flange inside the tank let that cure then, reinstall.
Any other easy fixes???
would using polyproxin quicksilver fix the bolt?
