Sponsored by:
Sponsored by: CARiD
I usually do not ask but HELP....
Old May 8, 2010 | 07:53 PM
rogue's Avatar
I cannot get this damn fitting to go back in... I do not know why it refuses to...
The clip is already in place, when I try to put back in the other line with the oring.. the piece of poo goes in a little and then will not snap into place..
I am trying to search online for solutions, but I do not even know what the clip or fitting is called.....
Stranded ATM......
Old May 8, 2010 | 08:57 PM
Ltdanish07's Avatar
Try prying the clip open when inserting the fitting. Maybe that will give you enough clearance to snap that SOB in there.
Old May 8, 2010 | 09:05 PM
mezzano1's Avatar
if the clip can removed then remove it, connect the lines then reinsert clip
Old May 8, 2010 | 09:39 PM
tephra's Avatar
pull the clip out...
connect the lines
push the clip on...
Old May 9, 2010 | 05:52 AM
waltezee's Avatar
connect the lines
push the clip on...
The clip is designed to hold the fitting in place not to flex to allow for easier installation.
Old May 9, 2010 | 07:45 AM
tephra's Avatar
yeh... but in saying that the male connector has a tapered leading edge which seems to indicate you can push the line in without removing the clip..
maybe rogue was just getting it caught...
either way removing the clip (if you can) should work!
Old May 9, 2010 | 07:55 AM
rogue's Avatar
been there done that. I created this tread after trying all that. I justed walked a mile and half to go get an oring since I damaged it...
Funny thing is that I had another connection like this that went in just fine..... It is the little things like this make you feel like a complete idiot when you can't get them to cooperate. blah.. going back outside now.
Old May 9, 2010 | 08:09 AM
rogue's Avatar
Funny how stuff just pops in when you try first thing in the morning... BS i say...
Old May 9, 2010 | 08:11 AM
tephra's Avatar
lol
Old May 9, 2010 | 08:14 AM
03lan-evo's Avatar
congrats man. i was going to say it looks like it just pushes right in..
Old May 9, 2010 | 09:20 AM
rogue's Avatar
Blah.. now the damn Clutch MC does not want to bleed lol..
Old May 9, 2010 | 09:51 AM
MicRX's Avatar
Originally Posted by kristokes
Sometimes all you need is some sleep and a fresh start.
Possibly the smartest thing ever said by any human being ever!!! It always works.
RallySport Direct
Evo X How Tos / Installations
40
Aug 17, 2015 07:46 PM
rogue
32
Dec 10, 2014 06:37 AM
RallySport Direct
Sep 4, 2013 08:46 AM
rogue
For Sale - Wheels / Tires / Suspension / Brakes
Dec 18, 2009 12:53 AM
ArchieBabes
Feb 6, 2009 05:41 PM
