Sponsored by:
Sponsored by: CARiD
oil in engine bay... oh my! =0
Old May 24, 2010 | 02:16 PM
bluegsr's Avatar
As the title reads, I installed my Cobb Access Port a few days ago, and I flashed her to 93 octane stage 1 base map. I was showing a couple of my friends how much harder the car pulls by doing some 1st through 3rd gear pulls. I didn't notice anything weird at all but when i popped my hood when i was done... I noticed some oil on my engine cover. is this something I should worry about?
PS. Some crappy cell phone pics of my car that i like ;]
Old May 24, 2010 | 02:18 PM
buchnerj's Avatar
Flames out the exhaust generally mean it is running pretty rich. What are your AFR's? As for the oil, did you check for loose breather hoses, etc? When you run higher boost levels you start blowing oil out of everywhere valve cover breather, etc...
Old May 24, 2010 | 02:34 PM
bluegsr's Avatar
i got a cobb ap so my AFR should be good, ill do some logs later
bluegsr's Avatar
ok guys there is literally no oil anywhere else, i even wiped that old oil off the engine cover and did some more pulls checked under the hood and nada, zip, zilch. should i be worried?!??!?
Old May 24, 2010 | 02:35 PM
TJs98GT's Avatar
maybe spillage or something? although it does look like dirty oil....
Old May 24, 2010 | 02:36 PM
buchnerj's Avatar
Just because you have an access port doesn't mean it will be spot on. That is a designed map for a few listed mods, but every engine is different. This is where standard tuning is lacked, every motor is different, different climates, etc... A tune should be personalized, but the AP is a nice piece. If you have flames like that in the exhaust though, usually it means you are running rich.
Old May 24, 2010 | 02:37 PM
bluegsr's Avatar
hmm i did get a service recently but im pretty sure iv looked under my hood since then. maybe i just didn't notice? im hoping its spilage, everything seems fine
Old May 24, 2010 | 02:38 PM
bluegsr's Avatar
flames were being spit out with the stock tune, i dont think i can shoot flames anymore
Kracka's Avatar
Make sure your dipstick is down snugly. I'm guessing just a few drops from your last service though.
Old May 24, 2010 | 02:40 PM
bluegsr's Avatar
yepp thats deff what it is because the oil did not look fresh, it had some dirt and grime in it and it left a stain on the cover so its deff from my last service. THAT WAS A CLOSE CALL!!!
Old May 24, 2010 | 02:48 PM
squid267's Avatar
+1 doesn 't look fresh at all. Flames....just no haha.
Old May 24, 2010 | 03:04 PM
bluegsr's Avatar
whats wrong with my flames ??
Old May 24, 2010 | 03:07 PM
SyZyGy1394's Avatar
Is that from your NAWWWWS?
Old May 24, 2010 | 05:16 PM
bluegsr's Avatar
lol no its from the crappy rich stock tune and no cat
Old May 25, 2010 | 07:11 AM
Enjoi411's Avatar
that last picture is awsome!!!!!
