Sponsored by:
Sponsored by: CARiD
AEM boost gauge, is this normal?
Old Jun 5, 2010 | 12:54 AM
dj_rock101's Avatar
I installed the AEM boost gauge couple days ago and had a ques. about it. When I step on the gas it shows about 6-10 psi but as soon as i let go it'll show 24-26psi. Is this normal, because the gauge would show normal psi (24-26) when I'm steeping on the gas, not when i let go of it. Also, under hard driving the gauge will show 0 psi, but as soon as i let go of the throttle it shows 24psi again.
http://67.59.157.230/ViewCategory.aspx?CategoryID=73
Old Jun 5, 2010 | 04:15 AM
Djstorm100's Avatar
wrong vacuum line
also know the difference when it is in KPA vs BOOST
Old Jun 5, 2010 | 09:01 AM
chkmgnt59's Avatar
what he said, you tapped the wrong line.
Old Jun 6, 2010 | 12:36 AM
dj_rock101's Avatar
I checked like 3 times and I followed the diy instructions pretty well. Also, I think it would constantly show 0 if I did tap the wrong line. I think, there's a calibration problem which is well know issue with aem
Old Jun 6, 2010 | 02:32 AM
Djstorm100's Avatar
It should show constant zeron regardless. it should show the vacuum, then go in to boost.
I havent heard or seen a calibration problem. I use their boost controller on my 9 second mustang and installed/tune on other case using aem stuff.. Good bang for the buck other than meth kits.
Old Jun 6, 2010 | 05:43 AM
dek0026's Avatar
Dumb question but do you realize there is vac and boost on a boost gauge? Not trying to insult you but I had to be asked.
I am starting to question the accuracy of this gauge as well but I will decide after i do a boost leak test.
Old Jun 6, 2010 | 08:41 AM
chkmgnt59's Avatar
i have the gauge, and its perfectly accurate. Can you take a pic of where you tapped for it? also, where did you run the line into the car? through the wheel well or did you drill through the firewall?
Old Jun 6, 2010 | 09:57 AM
KcEvil8's Avatar
the only negative thing about the gauge is it doesn't have a negative sign when it reading vacuum...that what 24-26 inches of vacuum you see when you let go of the throttle.
Old Jun 6, 2010 | 02:01 PM
dj_rock101's Avatar
thx for the input guys, I
Old Jun 6, 2010 | 02:11 PM
dj_rock101's Avatar
Thanks for the input guys, I had it run from the wheel well. I installed it again and the reading was off again. I found no sign of boost leak or pinching in the line. And, yes I know the difference between the boost vs vacuum reading. I bought it used from a friend and am planning to return it to him. I will either buy new aem or new defi soon!
Old Jun 7, 2010 | 05:29 PM
MonacoGP's Avatar
If the gauge doesn't read "0" with the ignition on but the car not running then you have either a bad gauge or sensor. Replace them both. Happened to me.
Old Dec 31, 2025 | 04:31 PM
Alberto0216's Avatar
I haw similar proble
Evo x here mine is tapped to the blow off on a t…..
I read 20 ish at idle and when I get on it it reads lower number up to 0
would this be normal? Or is sensor or gauge bad?
I have a leak on my downpipe could this be the reason?
Old Jan 1, 2026 | 06:23 PM
Jaraxle's Avatar
Boost gauge needs to go to the ENGINE side of the throttle body for proper reading. There is a port on the intake manifold that you need to T into there. Anywhere else is wrong.
Old Jan 1, 2026 | 08:59 PM
Correct but my other question is so I read o when it’s off when it’s idle I read anywhere from 20ish and when I get on it reads lower numbers up to 0 is this normal?
Old Jan 2, 2026 | 07:20 AM
schuhie's Avatar
20 what? I will assume you are talking -20 in-hg which would be normal. the engine is pulling a vacuum on the intake manifold at idle and until the turbo is creating enough pressure to cancel out the vacuum. Then boost pressure(psi) is just the positive pressure being created.
0 with the engine off is also correct as there is no vacuum or positive pressure with nothing moving.
