Does everybody elses stock tires wear like this??
so i take off my rims to clean them and i notice on my front tires that the inner part of my tire is almost bald! i have bout 11000 miles on my tires. i am lowered on coilovers and had an alignment done afterwards, but i jus was curious if my alignment is causing this or do the stock advans wear like this??
will get pics up when i get home on my computer
yes, mine were exactly like that actually... i'm going to have the alignment checked. I rotated them, as the backs looked pretty good, and i've got 12,500 on my car so I guess even if I replaced them now I didn't do to bad.
Could be toe or camber, tires don't wear like that by themselves. That said, the stockers don't last very long. Most people are replacing anywhere between 8k and 15k. Of course what one person considers 'worn' could be different from the next guy, and some people drive a bit harder than others... I replaced mine at 9.5k with a little bit left before I got to the wear bars, but I was having issues with those tires since my car sat on dealership lots for about a year before being sold- they had a lot of noise and a vibration that I could feel through the floor and pedals at any speed.
You mentioned you already had an alignment done, what were the specs? At you mileage I wouldn't necessarily think that you've got a problem- performance cars usually will have quite a bit of negative camber which will cause inner tire wear-- take turns harder
