Sponsored by:
Sponsored by: CARiD
cel still on!!
Old Jun 26, 2010 | 06:54 PM
RedEvoxGSR's Avatar
cel still on!!
ok dont know if anyone is familar with the speedcircuit test pipe but it has a lil welded on bung piece so it doesnt get the CEL well after about 20 miles the CEL came on.. so my question is why is the CEL coming on?? i have a defouler! what if i add a $5 autozone defouler will that help or will it come back on cuz the o2 sensor is to far away. i dont know what to do!! any suggestions would help! the pic is what the test pipe looks like.. and u can tell the special welded bung!
Old Jun 26, 2010 | 07:21 PM
rrkpitt15's Avatar
First off, Did you check to see what code you threw??? My buddy has the same test pipe and has never had a problem.
Old Jun 26, 2010 | 07:24 PM
Golden's Avatar
Are you tuned? If you are opensource, we can fix you up.
Old Jun 26, 2010 | 07:25 PM
RedEvoxGSR's Avatar
is it true that if ur CEL stays on ur car can go into LIMP mode?? thats what i'm worried about!
RedEvoxGSR's Avatar
no i'm not tuned.. jus have an accessport on the stock 91 oct map!
Old Jun 26, 2010 | 10:17 PM
monkey_187's Avatar
Connect the AP and check the code, you can also clear the code from the AP.
Old Jun 27, 2010 | 04:27 AM
RedEvoxGSR's Avatar
oh cool i ddnt know that!! but i mean it has to b cuz of te test pipe!! it was never on and then next day i had the test pipe on the cel came on!
Old Jun 27, 2010 | 07:01 AM
dek0026's Avatar
check the code and clear it if it is nothing big. cobb disabled a lot of codes when they made their tunes.
Old Jun 27, 2010 | 07:24 AM
RedEvoxGSR's Avatar
ok it says P0420 (bank1) that mean the first o2 sensor the one on the dp ???
Old Jun 27, 2010 | 08:06 AM
Golden's Avatar
What map are you running? Cobb disables the code for Stage 2 type maps.
Old Jun 27, 2010 | 09:19 AM
RedEvoxGSR's Avatar
im runing the stock map or stage 0 map cuz im stock except my test pipe
Old Jun 27, 2010 | 11:15 AM
monkey_187's Avatar
then you will be getting the check engine light cause of it, you need to change the map so you dont get it.
Old Jun 27, 2010 | 02:38 PM
RedEvoxGSR's Avatar
well i'm stock tho? which one should i use then?
Old Jun 27, 2010 | 02:50 PM
monkey_187's Avatar
there is no way of using the test pipe as the only mod and not throw the code. If you have an intake, TBE, you could run stage 2 and not get the CEL.
Old Jun 27, 2010 | 05:13 PM
Golden's Avatar
What is your engine management setup? i.e. cobb, openport 2.0 cable, none
