Sponsored by:
Sponsored by: CARiD
help me out...
Old Jul 13, 2010 | 06:06 PM
BAMFevo's Avatar
help me out...
hey im having some hestitation when i accelerate in higher rpm's. I thought it could be a mis-fire but the check engine light isnt on. I'm thinking it could be clogged fuel injector? anyone have any other thoughts or ideas???
thanks
Old Jul 13, 2010 | 06:21 PM
monkey_187's Avatar
did you make sure all your vacuum lines are hooked up?
Old Jul 13, 2010 | 06:51 PM
sailorcor's Avatar
^^^what he said. check the one on the front left side of your engine block. comes off very easily. also, what mods do you have? you may need a tune.
Old Jul 13, 2010 | 06:57 PM
churchja's Avatar
Check your spark plugs too... I think you're right that no check engine means you're not getting a misfire code... usually you'll get a P0300, PO301, etc. But, spark could be weak with no CEL.
A SpoonlinUp COP is a pretty reasonable investment if you think it could be spark blowout at high boost/acceleration.
Don't think it is your injectors being clogged or you would probably have other issues as well.
Old Jul 13, 2010 | 07:01 PM
es850revo's Avatar
check your Stock FPR lines and your coils.
Old Jul 13, 2010 | 08:07 PM
Noize's Avatar
EvoM Administrator
P0300s are almost nonexistent in the Evo X. On an unrelated note, the ignition system for the 4B11 is also substantially better.
Old Jul 14, 2010 | 01:41 AM
churchja's Avatar
That's really good to know... I didn't realize that there was any difference between the X and IX.
Sorry, I didn't read carefully...
