New mods always make me happier
Right now I'm running around 350awhp/340awtq on a dynojet, 91oct, peaking 25psi holding 22psi. Well, it's time for some more toys now. I want to be safe on my next upgrade and make sure I replace any stock parts that need to be replaced because of the new power I will be making.
I'm planning on getting:
FP Red Turbo
Kelford stage 2 cams
FIC 1100cc
Fuel Pump (what are some good brands?)
Clutch/Flywheel (need advice here)
CMC
BOV (brands?)
Here are my current performance mods:
Apexi RS Catback
Perrin DP w/HFC
AMS Intake
Forge Wastegate Actuator
AEM Tru Boost
ETS 3.5" FMIC, UICP & LICP
I'm pretty sure I need to replace my stock connecting rods and center diff pins. Are there any other parts like that, that need to be replaced since I'll be making around 450awhp/awtq? Thanks for any advice/tips!
FP Red Turbo
FIC 1100cc
CMC
BOV (brands?)
Apexi RS Catback
Perrin DP w/HFC
AMS Intake
AEM Tru Boost
Fuel rail you won't need to worry about so much. It wouldn't hurt to do the fuel pump, and bov. If I were you I'd do the CMC and clutch/flywheel for preventitive measures. With your new power levels the clutch will more than likely go sooner rather than later. And with getting a new clutch I've seen most recommend a new CMC. Also, consider diff pins and then without question you'll be all set! Good luck with the build and keep us updated!
The Dominator doesn't seem to be a popular turbo upgrade. I seem to remember reading something about surging issues.
If you want spool, get a Green.. If you want peak power, get a Black (spools ~300 later than red with more power potential)
Thanks for the advice. Honestly, I had the 2.0 in mind cause that's what was out months ago and I just started thinking about finally doing something now. I did some research and I think I like what I see with the FP Green!
