Sponsored by:
Sponsored by: CARiD
umm my turbo isn't spooling
Old Nov 25, 2010 | 07:21 PM
meat_EVO's Avatar
Originally Posted by max4rw
this is so common when changing out the stock plumbing! it will more than likely happen again, get rid of your under tray and always carry around a small set of tools! this way if it happens again and your a ways away from home you can easily fix and be back in business!
no, just tighten it right the first time. leave your under tray on. why would you take it off? loss of Aero and Dirty enginebay?
Old Nov 25, 2010 | 07:34 PM
oftheheavens's Avatar
agree. I just tightened them up correctly and doubt there will be any problems....if they come undone i will be sh*tshockamazed.
Old Nov 26, 2010 | 06:07 AM
Hiboost's Avatar
BTW leaving the undertray off for a few days/weeks is one thing, off permanently is another. After talking with some of the techs that replaced the assessory pullies on the Evo X MR that ran last spring's one lap event, they mentioned that the reason the pullies were worn out was because rocks and other debris were getting kicked up into the belt while driving which accelerated wear rapidly. Possibly the center area can be left off without too much worry but the two side sections are critical to keep the belts clear from wear.
Old Nov 26, 2010 | 06:12 AM
Originally Posted by stageup
hey how tight did you torque all the tbolts? i'm installing mine right now and don't want to bend the pipes hah!
i tightened as much as they would go and the cobb pipes didn't bend.
Old Nov 26, 2010 | 04:27 PM
max4rw's Avatar
Because in reality nothing fits as well as stock! doing it right the first time is defiantly key! but even then there is a possibility of having something pop off or become lose over time! if your car is a daily driver, the little loss of aero from removing your under tray should not be of concern! people have mixed feelings about removing their under tray. I can only speak from my experience. I have had no negative issues what so ever from removing it. I defiantly dont miss having to take it off and put back on every time I need to do maintenance on my car!
Old Nov 26, 2010 | 07:06 PM
stageup's Avatar
ok i tightened mine to the point of the 2 sides of the t clamp touching on most, and almost touching on the others, hopefully it stays
edit: damnit forgot to use hairspray on the uicp and licp, i did use it on the fmic before putting the couplers on tho arghhhh
Old Nov 26, 2010 | 09:51 PM
mrMTB's Avatar
Don't listen to max4rw- the undertray on the CT9A was a ***** to take off and reinstall (I should know as I did it on the side of the road four times one weekend). The undertray on your car is much easier to deal with.
Aside from the above, remember that when Mitsu was designing your car, the engineers and bean counters got into a fight about that very undertray. At the end of the day the engineers won (the value of having the undertray in place outweighed the cost).
Old Nov 27, 2010 | 04:44 AM
max4rw's Avatar
dident know the under tray on the 10 wasent that much of a hassle to get off, in this case i agree leave it on!
EVOII
10
Feb 25, 2016 11:09 AM
JV21804
19
Oct 30, 2013 11:03 PM
alex the great
Mar 23, 2013 09:48 PM
LoveBoost
49
Apr 27, 2007 06:20 PM
imapunkclaimer
Lancer Aftermarket Forced Induction Tech
17
Apr 21, 2005 06:47 PM
