What to look for in a 2008 Evo X
Check for a oil leaking with oil on the engine tray in the vicinity of the oil filter. It was a problem on the early cars which was supposed to be fixed with a TSB (the TSB "fix" consisted of plastering goo around the outside of the timing chain cover).
Check the front brake caliper color if you want to see if it has been to the track...took less than a day to change mine from bright red with white lettering to a very dark red (almost brown) with gold lettering.
Other thing would be to check for mods, especially if buying from a dealer where you can't talk to the previous owner.
Still under warranty though so don't have to pay S*!t...
Fuel relays? A known issue really. Also, if you are familiar, take a look at the boost solenoid lines and verify they are properly routed.. Check the exhaust system too.
In general, do your best to verify it's not been molested.
