Sponsored by:
Sponsored by: CARiD
Turn Signal Relay ??? .....
Old Feb 24, 2011 | 10:25 PM
theFLASH12's Avatar
Can anyone tell me where it's located? in the fusebox under the steering column or the engine compartment? What does it look like?
Help will be much appreciated !!!
Old Feb 24, 2011 | 10:33 PM
migs647's Avatar
There isn't one. It's built into the car. Why do you ask?
Old Feb 25, 2011 | 11:49 AM
theFLASH12's Avatar
Thanks for the info !!
I plan on going LED replacement bulbs which of course would required adding load resistors. There are replacement relays to avoid having to add load resistors.
Old Feb 25, 2011 | 12:44 PM
migs647's Avatar
Gotcha, there has been threads on running LEDs, I'm not sure of the success. Search the lancer side of things as well.
Old Feb 25, 2011 | 08:09 PM
lancerarmstrong's Avatar
load resistor by itself should be fine. just use heatshrink and match the oem bulb's resistance with your resistor and LED combined when on (aka impedance)
goforwand
Dec 29, 2013 07:47 PM
kpt6
17
Jul 31, 2013 01:14 PM
