MDF II V.S Gauges
MDF II V.S Gauges
Okay, I'm by no means a Super mechanic or a pro tuner but I was curious as I'm getting into it what is the best choice when it comes to reading Boost, A/F, Oil/Water temp. I only ask because I noticed that my 2010 MR dosn't show me the Oil/water temp and also I was going to get a boost gauge but came across this.
http://www.arkdesign-us.com/products...unction-dash-2
Now to me that looks super badass but I was curious if there's a problem with digital display vs actual gauges.
The only issue with the MDF2 is that
Other than that its pretty nice (I've seen it at a few meets).
- Its expensive
- There are a lot of extra things you have to buy to fully utilize it
- It takes up the OBD2 port
- it has the same limitations of anything attached to the OBD2 port
SO what are these limitations? Because if i install the sensors I would be gettin real time readings right? I heard the OBD2 slot was delayed in it's readings? Just curious before I spend a ton of money on something, you know?
