Sponsored by:
Sponsored by: CARiD
People with AMS intakes please PLEASE READ.
Old Aug 17, 2011 | 11:09 PM
Trenalsur's Avatar
Exclamation People with AMS intakes please PLEASE READ.
Hi everyone,
I bought the AMS ram intake black. It has an open air filter. I installed the intake and my idle became erratic. If i turn on the air conditioner my car will die. Its died twice in the past when the air gets turned on and my car is sitting.
So I took it off and put the stock air box on and my car runs normal again.
So heres my question:
If I get my car tuned will the erratic idle go away?
I paid a lot of money for this POS and I don't want it sitting in the house collecting dust.
Thanks for reading.
Old Aug 17, 2011 | 11:23 PM
Og Neon's Avatar
did you install the shield to block the air coming off the radiator fan? Also the AMS intake changes the size of the MAF and it is recommended that you have a tune for it.
Old Aug 17, 2011 | 11:28 PM
margie's Avatar
If the AMS intake you have is the short ram, do you have the shield on? With the a/c on it blows into the intake. I believe with this intake you should get tuned right away. I dont think it uses the stock maf size like ETS does.
Edit: Yes, what Og_Neon said as well. Others will probably tell you the same thing.
Old Aug 18, 2011 | 04:57 AM
h4ckluserr's Avatar
Yeah, confirmed. pretty much any cold air/ram air systems are going to need a tune or they run like garbage. the tune will take care of the erratic/failing idle
Old Aug 18, 2011 | 08:23 AM
AutoMotoSports's Avatar
To reitorate what was stated the car must run the supplied fan shield. Did you buy this new from us or used? If used and you did not get a fan shield we can sell you one for the car.
IN addition as was stated some cars done react well to the intake without a tune so the car can react a bit erratic. A tune is always a good idea
Does the car have a tune on it already? If it did adding the intake will only make that problem worse.
Eric
Old Aug 18, 2011 | 08:56 AM
ugakirk's Avatar
I think that you just need to get the intake shield..
I don't think that this is as much of a tune related problem, as it is the hot air getting blown into the open element filter..
Old Aug 18, 2011 | 08:58 AM
ETS Michael's Avatar
Originally Posted by Trenalsur
Hi everyone,
Thanks for reading.
You will want to make sure you get the shield on the intake or else the radiator fan will blow directly into the MAF causing an erratic idle surge. If the intake doesn't use the factory MAF housing. It's going to need a tune. The MAF must be rescaled to run correctly.
** The factory MAF housing is the black piece between the filter and pipe. If the MAF is directly on a 3.0" pipe, it must be retuned.
Thanks!
Michael
Old Aug 18, 2011 | 08:59 AM
Ricekiller81's Avatar
I worked on an Evo X last year with an AMS intake all you need is the Shield man Problem solved along with a tune.
Old Aug 18, 2011 | 09:02 AM
DriveHard_99's Avatar
I've had some experience there with some of my previous sports cars and when applying the additional air your changing the combustion so are fuel ratios might need to be changed.
For example some cold air intake manufactures make intakes that require no tune and some that specifically require a tune but those that do are generally the best as they will ultimately provide more HP.
Old Aug 18, 2011 | 09:52 AM
Trenalsur's Avatar
Oops... Lol
I have the heat shield, but couldn't see how to install it. I saw the instructions,but didn't see how to install the shield. I will try again sorry.
Old Aug 19, 2011 | 04:43 AM
santeller's Avatar
I installed mine about 2 months ago and before i used the cobb ap tune did the exact same thing all you need is a simple mild tune. my idle has always been a little off the intake actually helped a little.
Old Aug 19, 2011 | 04:51 AM
pghdsm's Avatar
I have a 2011 GSR with the AMS short ram and I have zero issues with idle. However the 2011s have a better tune from the factory.
When I had my 2008 with my AGP intake it idled like garbage until i flashed my ecu. Get a tune and call it a day. They gave you the heat shield for a reason..
Old Aug 19, 2011 | 04:57 AM
NewEvolutionIX's Avatar
My IX does this with the Buschur intake and was tuned and still does the same thing
kamote2000
Sep 30, 2016 10:50 PM
Caino
Jul 9, 2015 07:40 AM
Stubbie68
Jun 29, 2015 03:45 PM
josephcastelar
Apr 22, 2013 11:37 AM
AkumaMotorsport
Oct 30, 2011 11:27 AM
