Sponsored by:
Sponsored by: CARiD
View Poll Results: To catch or not to catch?
Catch
18
72.00%
No Catch
28.00%
Voters: 25. You may not vote on this poll
Old Aug 20, 2011 | 10:05 AM
The_X_Effect's Avatar
Thinking about getting a catch can, but not sure if i really need it now or not. My biggest concern is that im switching to e85 and im projecting my numbers to be around 400whp and 360-380 wtrq. My car is also brand new with only 4500 miles on it and will be just dding with it. No track use or strip for now but i will let her rip here and there.
Old Aug 20, 2011 | 01:55 PM
Can you explain why you would or wouldn't. Im also wondering what ur thoughts are besides the poll
Old Aug 21, 2011 | 07:58 AM
dee242's Avatar
Originally Posted by the_x_effect
can you explain why you would or wouldn't. Im also wondering what ur thoughts are besides the poll
+1
Old Aug 21, 2011 | 03:27 PM
Mitsulover's Avatar
i can understand using a catch can for racing/autocross but is it effective for a DD? Can someone that only uses an X as a DD chime in and comment on whether they see the catch can filling up?
Old Aug 21, 2011 | 04:30 PM
Kracka's Avatar
I honestly wouldn't bother, especially on a street car. A properly setup and designed catch-can system is good but 90% of the ones I see are wrong and if anything causing more problems than they're solving.
Old Aug 21, 2011 | 06:10 PM
Gooseman396's Avatar
I run the dual sakiou michi setup. My evo x is a daily driver each oil change I get about 2-3 ounces or gas/oil caught. I would say its worth the effort if you do it right I have not had any problems.
Old Aug 21, 2011 | 06:22 PM
horse-eater's Avatar
agreed, there is always blow-by.
small steps to make things more reliable imo.
Old Aug 21, 2011 | 07:00 PM
Good to hear. Since we both are driving 2010 Gsr's how exactly is yours hooked up. There are many different ways its seems to hook the catch can up. Please if you could be detailed that would be appreciated. Thanks
Old Aug 22, 2011 | 09:18 AM
Ill post some pics tonight, I think that's the easiest way to explain the setup.
Old Aug 22, 2011 | 09:30 AM
Mad_SB's Avatar
I just ordered my dual Saikou setup a couple days ago.... An improperly designed catch-can or improperly plumbed setup is useless. I had a greddy can on my VIII and hardly caught anything in 20k miles... I have also seen a lot of cans that are vented to the atmosphere... not very useful.
Get a properly designed can or cans (baffles and filter material in the can), plumb them so they don't leak under boost or vacum and make sure they are routed properly (port on the front of the valve cover near the FPR should be plumbed to the intake manifold and have a check valve in it, port on the side near the turbo should route back to the intake pipe before the turbo to pull a constant vacum). Or don't bother at all.
Old Aug 22, 2011 | 09:40 AM
I agree with Mad_SB get a quality can otherwise it will just travel though the can and not catch anything. Pics of the dual setup coming.
Old Aug 22, 2011 | 05:04 PM
Cool thanks....i just ordered there split dc3 setup
Old Aug 22, 2011 | 06:57 PM
I have attached some pics of my setup let me know if you have questions I will be happy to answer them.
Attached Thumbnails To catch or not to catch?-img_20110822_163530.jpg   To catch or not to catch?-img_20110822_163541.jpg   To catch or not to catch?-img_20110822_163616.jpg
Old Aug 23, 2011 | 06:57 AM
Looks good mine should look the same except for braided hoses
Old Aug 23, 2011 | 07:47 AM
SPANKED's Avatar
I just got my Dual Saikou. So where did you pick up the check valves and how many do you need? Thanks.
