Sponsored by:
Sponsored by: CARiD
Best BoV for Evo X?
Old Dec 7, 2011 | 11:47 PM
  #31
iEvolutionX's Avatar
Majority of the X owners I've spoke to were very content with using the stock BOV...
Old Dec 8, 2011 | 12:20 AM
  #32
Evolution Z's Avatar
Originally Posted by anEVOx
Do you have any proof of this? I've seen many many owners run VTA with very little, if any side effects let alone engine damage. I'm also pretty sure you can be tuned for VTA as well. I do understand the MAF issue btw.
In the end I think you're better off running recirculation however.
proof as in personal experience? (or any other kind for that matter?) no i dont;
but if you look at the math/physics of what's happening, it certainly isnt "helping".... like you said, which i agree, it is possible to have a tune with vta... however, if your tune was with a recirc. system, then certainly something may go wrong if you run vta on that tune
math:
let
A= filter air passing thru the maf
B= bypass airfrom bov
C= total air into engine
bypass valve:
C = A + B
Vent thru atm:
C = A - B
like i said... problem may stem from that portion of un metered air if not tuned for such a set up
Old Dec 8, 2011 | 03:26 PM
  #33
1evil240's Avatar
Evolution Z is right. What happens is that the MAF measures how much air enters the engine. Then with this number measured the ECU calculates the amount of fuel to be injected into the engine to combust with the air to achieve maximum efficiency.
For example, lets say the MAF measures 100 particles of air, then the ECU has the injectors give enough fuel to burn the 100 particles. If you vent to atmosphere the MAF will measure 100 particles but then you lose 40 to the atmosphere, the ECU will still give enough fuel to burn 100 particles but actually 60 get to the engine (100-40). Then you have excess fuel in the engine which doesn't combust and so u will run rich. Then the excess fuel will travel through your exhaust and once it reaches the end of your exhaust pipe, the fuel will meet air and combust at the tip of the exhaust making a loud back fire noise and over time you get that black stained rear bumper.
I personally love the sound of loud blowoff valves. You need to have your car tuned if you want to vent to atmosphere. I had a Greddy RS and it was the worst blow off valve because it leaks. It leaked after 2 months of only 14psi. It leaked with all my friends. I had an HKS that was really good but I didn't like the sound. Find one that doesn't leak under boost.
Old Dec 9, 2011 | 05:35 AM
  #34
deanob's Avatar
If your running under 25psi stay stock. And even then if you need to go beyond that you can get away with crushing the BOV to hold more.
Old Dec 9, 2011 | 07:43 AM
  #35
jdmEviL8's Avatar
ive been running the turbosmart dual port for about 5 monts. no problems here, by far the loudest bov ive ever owned
Old Aug 5, 2012 | 11:53 AM
  #36
dal35's Avatar
I'm told by other Evo shops to stick with stock.
Old Jul 16, 2013 | 04:36 PM
  #37
GoosEvo X's Avatar
I have the Hks cold air intake. The maf sensor is at the front, the bov being at the back. How does it measure the air being recirculated? Also, since everyone keeps saying stay stock on the bov. what if your rocking higher boost and you want a honest opinion of what the best bov for the x is. Any help would be appreciated.
Old Jul 16, 2013 | 08:19 PM
  #38
xtremecb7's Avatar
Bov
I just picked up a 08 x amd looking at gfb What about the go fast bits respons can set it 50/50 sounds good on YouTube
Old Jul 22, 2013 | 03:02 PM
  #39
JezzaX's Avatar
Stock is best, until you get crazy with the engine then it's Tial.
Old Jul 24, 2013 | 07:36 PM
  #40
Flossy_X's Avatar
I have Tail BOV! Sounds great!!!!!!
Old Jul 25, 2013 | 10:39 AM
  #41
GoosEvo X's Avatar
I am going to try turbosmart's bov. Ill post what I think about it after install and test it. Reason for.replacement being that factory is leaking wot and is getting worse.
Old Jul 25, 2013 | 10:44 AM
  #42
FastAttack's Avatar
Tial QR ftw
stock turbo stay with the stock one..
Old Jul 26, 2013 | 02:59 PM
  #43
Maz's Avatar
Maz
Stock FTW! Stock and throw in a Cold Air Intake or Short Ram Intake and enjoy
Old Jul 26, 2013 | 04:39 PM
  #44
golgo13's Avatar
EvoM Community Team
Veteran: Navy
10/10 would read again
Old Jul 26, 2013 | 05:38 PM
  #45
Iowa999's Avatar
10/10 is for wusses.
