Sponsored by:
Sponsored by: CARiD
Evo X in snow ?!?!
Old Jan 1, 2012 | 02:47 PM
Mayh3mNVEvo's Avatar
Evo X in snow ?!?!
so whats the trick to drving this car in snow ....I came off of having an STI and that was bad *** in the snow and this car is all over the place.. Ihad a ton more power in the STI..Please Help !!!!
Old Jan 1, 2012 | 02:50 PM
ExtremeDSM's Avatar
Tires!!!!
Old Jan 1, 2012 | 02:52 PM
slowx's Avatar
Make sure you have good tires. When I first picked up my evo, the first purchase I made was a good set of winter tires. I picked up a set of Blizzaks and they are amazing.
SamsonEvoX's Avatar
Simply put, best car I have ever driven when used with snow tires. I had a small thread on this in November: https://www.evolutionm.net/forums/ev...011-evo-x.html
There are lots of threads on this subject btw.
Old Jan 1, 2012 | 02:55 PM
SamsonEvoX's Avatar
Peruse all these threads I found by searching for you: https://www.evolutionm.net/forums/se...rchid=16926627
Old Jan 1, 2012 | 03:05 PM
dsmbruno's Avatar
Tires... Just watched an episode of US top gear and they were killin it in the snow
Old Jan 1, 2012 | 03:23 PM
T6's Avatar
T6
dont use extreme summer performance tires.
depending on where you are all-season tires will do the trick, if not get blizzacks.
Point and gun it then jerk the other way around and start drifting in a CLOSED road/parking lot.
Old Jan 2, 2012 | 06:47 AM
dewey1231's Avatar
Tires. I live in Minnesota and I use all seasons (highway driving) instead of blizzaks and they work great. Summer tires are horrible on show and ice.
Old Jan 2, 2012 | 07:07 AM
black95tt's Avatar
Why do people still not understand that you can't use SUMMER tires in the snow?
Old Jan 2, 2012 | 07:21 AM
scheides's Avatar
EvoM Moderator
Why do people always assume he's on summer tires? OP lives in Reno so its possible but if he had an STi before I would HOPE that he knows how important tires are.
Like someone said above, I have to add a +1 to the X being the best car I've ever driven in the snow. The between AYC and the extra weight over my evo8, it is leaps and bounds better, simply amazing.
OP, do you have any CELs at all, maybe your AWC system is acting up?
Old Jan 2, 2012 | 07:43 AM
tsidrift1's Avatar
If the car is all over the place, I cant help to think that your still on stock Advans?? If so, you def. need to get some tires. Thats my only assumption. We've had a few dustings of snow so far this year. My g/f's evo x has the continental dws and it gets around great.
Old Jan 2, 2012 | 07:55 AM
Robevo RS's Avatar
here is one of your best possible trick for DD. in the snow and winter.
You need nothing more then that, and the same token nothing less then a dedicated winter +snow tire for a winter.
http://www.tirerack.com/tires/tires....97&sortSize=18
Old Jan 2, 2012 | 09:08 AM
Get Rad's Avatar
This. And if you can't drive this car in the snow you shouldn't be driving any car in the snow.
Old Jan 2, 2012 | 10:35 AM
black95tt's Avatar
I'd say it's a pretty good assumption. Seven posts, MY 2010....still on stock tires I'd bet. If he was on a good all season or winter tire, would he have posted this question?
No.
*edit* I think this dude is trolling.
Old Jan 2, 2012 | 11:00 AM
TheBlade's Avatar
There's even a warning when you buy a X that the Yoko A13's aren't to be used as winter tires. Hope the tire's is the answer the OP needed.
