Sponsored by:
Sponsored by: CARiD
hi flow cat question?
Old Jan 20, 2012 | 07:35 AM
CaptainAsia's Avatar
Hello, so im debating on two different scenarios:
Get a hi flow cat and run on the stock exhaust (would i see any gains?)
Get a cat back exhaust (more money and no hi flow cat)
Would getting just the hi flow cag be worth it and if so any recommendations?
Old Jan 20, 2012 | 07:36 AM
Kracka's Avatar
A HFC (or testpipe) will show better gains than just a catback. If you insist on using a cat, check out Mil.Spec's 100-cell.
Old Jan 20, 2012 | 07:41 AM
So I can run just the cat alone with the stock exhaust?
Old Jan 20, 2012 | 07:45 AM
Also do i need a tune to run it?
Old Jan 20, 2012 | 07:50 AM
whoang40's Avatar
No you don't but you won't get the best gains, probably won't even feel a difference with the mod. My advice is save up a bunch of money for the mods you want, install and tune at once to save money.
Old Jan 20, 2012 | 08:02 AM
khmerguyx's Avatar
^^^ Thats my plan but first I need an evo
Old Jan 20, 2012 | 08:31 AM
S2K2EVO's Avatar
Along the same lines is is safe to run a catback and test pipe without a tune?
Old Jan 20, 2012 | 08:33 AM
Kracka's Avatar
Probably, why not tune it though?
Old Jan 20, 2012 | 08:55 AM
AV6JT's Avatar
I thought test pipes/HFC would not respond too well without a tune? I thought i read somewhere that it would make the car run lean? or maybe thats the downpipe..
Old Jan 20, 2012 | 09:12 AM
No tune because Im low on funds, maybe just get an access port instead, is there an ots tune just for a cone filter?
Old Jan 20, 2012 | 09:14 AM
Kracka's Avatar
A stage 1 AP OTS map will provide more gains to a stock car than bolting on a testpipe & catback w/o tune. Yes, there is an OTS map you can use with just a filter.
Old Jan 20, 2012 | 09:25 AM
S2K2EVO's Avatar
[QUOTE=Kracka;9903835]Probably, why not tune it
I want to stay tune free, but I guess I can always unmarry the AP if I need to go in for work. If I was going this route I would just buy the AP now before any other mods.
Old Jan 20, 2012 | 09:52 AM
beetle_orange's Avatar
i was so close to doing this, hfc with stock exhaust until i came across the catback i have at a price of a hfc.
Old Jan 20, 2012 | 10:19 AM
Which catback is this?
Old Jan 20, 2012 | 10:34 AM
ericjai113's Avatar
I believe the most restrictive part of the exhaust is the cat, but would a high flow cat set off CEL?
I am on the same boat here, I want to get a CBE too, but you probably won't gain much except for sound and look
Does the 2011 Evo has a new stock exhaust that flow better? if that's the case, I may just upgrade the cat...
