Sponsored by:
Sponsored by: CARiD
stock cat, hi-flow cat, or strait pipe?
Old Jan 25, 2012 | 04:23 PM
Evolution Z's Avatar
Smile stock cat, hi-flow cat, or strait pipe?
Will be picking up an exhaust soon (catback)....
keeping power in mind as well as yearly state inspections, should I leave the stock cat on there? or at least upgrade to a high-flow cat or just use a test pipe (cat delete)?
thanks!
Old Jan 25, 2012 | 04:25 PM
evo jason's Avatar
IMO it depends on where you are located and the local laws. I'll be running a high flow cat because I'm in CA.
Old Jan 25, 2012 | 04:27 PM
yeah good point, i live in NY and theyre pretty strict about that stuff here, so maybe I'd be best with a high flow cat.... no CELs should be produced either (right?)
Old Jan 25, 2012 | 04:41 PM
evo jason's Avatar
I think some of them can throw a code, I would just do some research and searching around on the forums before you buy. With the right high flow cat there shouldn't be any CELs.
Old Jan 25, 2012 | 05:44 PM
tkromer's Avatar
If you have a sniffer in your state, you'll at least need an HFC.
If you're just worried about the code, you can always tune that out and go with a straight pipe -- although the noise may make some inspection stations a little nervous.
Old Jan 25, 2012 | 05:51 PM
Gigsohard's Avatar
i run a tp with cat shields
Old Jan 25, 2012 | 06:52 PM
Robevo RS's Avatar
The power difference between the resonated test pipe vs the milspec highflow cat(100 cell) is negligable. So i would get a hfc. Less noisy and less smelly.
Old Jan 26, 2012 | 06:19 PM
SwissMTNAlien's Avatar
I went with a straight test pipe because it was cheaper and I wanted more power. However, I would probably have gotten a HFC if I could do it over again so I wouldn't have to worry about inspection. It's probably only like a 5whp difference between cat or no cat.
Old Jan 26, 2012 | 06:23 PM
8UpUrV8's Avatar
Depends if you're getting tuned.
A tuner can tune a nice mil spec HFC to not thrown codes and you'll make good power, and be legal...
Otherwise, you need a restrictive cat to please the stock ecu and not throw a code...
Old Jan 26, 2012 | 07:04 PM
no sniffer in NY, i will get a tune after. ill probly go with a hfc... but i lold at a tp with cat shields... take THAT new york!
Old Jan 30, 2012 | 05:22 PM
Mitsulover's Avatar
Yup, no sniffer in NY. I run test pipe and there is a gas smell.... kind of annoying. My car came that way but I'm thinking of getting a HFC when I get a chance. The only thing is I'm tuned on the TP whether it would make a difference or not I don't know. A HFC from what I've read won't make much of a difference reducing the smoke though...... maybe reduce it a bit but not much.
floating doc
Jan 18, 2017 11:29 PM
Evoxsstmr
May 31, 2016 08:11 AM
chris4b11t
Nov 21, 2013 06:16 AM
ekizenbe
10
Oct 7, 2010 10:38 AM
MrBonus
19
Aug 12, 2008 06:13 AM
