Which AFR Gauge do you have?
you mean during the install? it wont go off. If you get the rexspeed one u dont even need to take the stock pillar off. If you get the dsg one its easy to swap them around. Theres less then a .00001% chance it will go off.
if you are talking about it going off while driving and the gauges hit u in the face, the pillars have a little hook to prevent them from flying at you.
Would suck if it came flying at you but if you pull your oem pillar off, there is a hook that is hooked into the frame that prevents it from coming at you when the airbags deplay. The gauges will only pop out about 2-3 inches.
