Sponsored by:
Sponsored by: CARiD
ETS Intercooler Kit
Old Feb 4, 2012 | 09:45 AM
Alpha X's Avatar
ETS Intercooler Kit
Well I finally pulled the trigger and purchased the FULL ETS Intercooler Kit from ETS themselves! Got an awesome military discount
Now will I be able to install this on my own OR will i need to take it to my tuner? Not sure how much they will charge me to install it. My mechanical skills are limited
Old Feb 4, 2012 | 09:47 AM
Evolution Z's Avatar
remove the top plate, remove front bumper, remove skid plate under car, un-do a few mounts, drop old one, slap new one in, boom- done.
:P
Old Feb 4, 2012 | 09:48 AM
margie's Avatar
https://www.evolutionm.net/forums/ev...lustrated.html
Old Feb 4, 2012 | 09:54 AM
Alpha X's Avatar
:P
Sounds easy enough lol. But if I did take it to a shop how much do you think they would charge?
Old Feb 4, 2012 | 09:56 AM
Wildcat Birdie's Avatar
they will charge you labor only since you have the parts. depends on what the labor rate is there. my guess would be approximately three hours or so.
Old Feb 4, 2012 | 10:12 AM
Alpha X's Avatar
My concern is the lower intercooler piping. I saw the instructions to remove the FMIC and the LICP seems to make that bend and disappear? I'm a noob
Old Feb 4, 2012 | 10:19 AM
GTbullet's Avatar
honestly its the easiest thing to do. hardest part is "ripping" the bumper off of the clips. I say do it yourself, spend the labor money on more parts and get to know your car!
Old Feb 4, 2012 | 10:31 AM
this
Old Feb 4, 2012 | 11:30 AM
Sev's Avatar
Sev
I'm mechanically limited too, lol. I'd take it to a shop. Just my .02.
Old Feb 4, 2012 | 11:57 AM
RevLimiter's Avatar
I would do it myself. It's an easy bolt on project. Taking off the front bumper requires 10mm socket, a screwdriver and about 20 min if it's your first time.
To take of the the IC pipes it's just loosening the worm clamps of the couplers with a Phillips screwdriver. The undertray is 6/8 10mm bolts and some plastic clips. Time consuming but not hard.
Hope this helps
Old Feb 4, 2012 | 12:10 PM
jestoy7's Avatar
Old Feb 4, 2012 | 01:22 PM
vanilla2's Avatar
First step to becoming mechanically inclined is taking on a project like this. I say do it yourself.
Old Feb 4, 2012 | 08:41 PM
Snakes709's Avatar
install it yourself. Just follow the how-to guides on the forums and you will be fine. I'm going to say it will take 2-3 hours, so roughly $200-300 to install. You could buy a intake or something with that money.
Old Feb 5, 2012 | 12:18 PM
Zerofour1223's Avatar
Id say do it yourself too, the guides on here are fantastic and youll learn more about the car. As others have said youll also be able to put the money saved towards other things. Just print out a guide and spend some time in the garage, itll feel much more rewarding
Old Feb 5, 2012 | 12:39 PM
linkbeat's Avatar
It's easy, just do it yourself. Just follow the video guide linked above.
