Sponsored by:
Sponsored by: CARiD
yet another evo X erratic idle
Old Jun 2, 2012 | 05:57 PM
deraz's Avatar
Originally Posted by EuroEclipse
Here is the order that I would check things... I'm no expert, though. So take this all as just things that I've done in the past with my DSM's and my Evo IX and X.
Boost leak check - You've already done this
Soapy water test on all IC piping - If you see bubbles, there is a leak.
Check all vacuum lines
Check MAS sensor
Check PCV - It's a 2008, so it shouldn't be bad. It's just a good idea to check it.
Check BOV for broken diaphragm/leaks
Check throttle body/clean throttle body - You've already done this.
Check Cat
If all else fails:
Check air filter and replace if needed
Install boost gauge and watch the readings
Check clutch master/slave cylinder and ensure the clutch is properly engaging.
After a long battle, I think I am making some headway. I decided to begin an all out cleaning of the intake system. Started with the pre-turbo pieces. MAF cleaning and reseating all air cleaner/piping leading to turbo. I got as far as the MAF and also did what I believe is the MAP sensor on the intake. This seems to have worked as the surging idle has just about disappeared.
Old Jun 2, 2012 | 08:07 PM
EuroEclipse's Avatar
Awesome
Old Oct 15, 2013 | 10:35 AM
SSP Jason's Avatar
Did this ultimately rectify the problem? I'm having major issues with this currently after my build. I thought it was oil pressure...but it seems to idle fine from time to time.
Old Oct 16, 2013 | 06:56 PM
littlezrexer's Avatar
You are wasting your time, it's a problem with the stock map, the problem is that the computer switches idle tables and the car cannot keep up with it, resulting nj surging idle,
I've personally had this issue with a off the shelf Cobb map and modified it myself to fix this issue. Ask any evo x tuner.
http://www.evoxforums.com/forums/showthread.php?t=56314
najo
14
Dec 30, 2016 07:46 AM
josephcastelar
Apr 22, 2013 11:37 AM
maradits
Dec 13, 2011 08:09 AM
npham455
Aug 4, 2011 06:40 PM
