Sponsored by:
Sponsored by: CARiD
Need help (installing clutch)
Old Dec 22, 2012 | 06:11 PM
bandalgom78's Avatar
Hi everyone. I am calling out all evo x expert out there.
I am installing clutch and it is pain in ***. i am stuck on step that removing transfer case
If you are from San Diego and know how to install clutch, please help me out!
Maperformance how to install is really confusing for me.
Old Dec 23, 2012 | 11:10 AM
Snakes709's Avatar
What about the transfer case are you having issues with? Did you remove the axle stub out of the transmission? If not theres your probably right there. If you did, then put your purse down and pull it off. Once all the bolts are removed the 6 bolts, all you need to did is move the transfer case up and down, at the same time pulling it to the passenger side. Its a ***** to get it off the spline from the transmission but its not impossible. I recommend having a second person to help you since the sucker is 75lbs, if not expecting it to fall and you are under it, it may result in injuries. If you arent under it and it drops, you may damage it.
brokenRS
West Region
4517
Oct 6, 2015 08:11 AM
gabegonzales
May 21, 2013 08:52 AM
edwinisdumb15
West Region
Apr 22, 2013 02:36 AM
umopp
Mar 27, 2011 02:12 PM
