Sponsored by:
Sponsored by: CARiD
Is this how you bypass a boost solenoid? (diagrams in here). For Aem Failsafe Trigger
Old Sep 22, 2013 | 09:00 PM
johnnnyjeans's Avatar
this is for the AEM failsafe.
http://www.evoxforums.com/forums/showthread.php?t=67023
DISCLAIMER. I HAVE NOT DONE THIS YET. PLEASE SOMEONE CONFIRM THIS FOR 100% ACCURACY. TRY AT YOUR OWN RISK. UT_EVOX IS NOT RESPONSIBLE FOR ANYTHING.
Old Sep 22, 2013 | 09:50 PM
according to ut_evox
"You're going to blow your ECU like that. What you want is a SPDT relay that can be wired to be normally closed and then open when ground or 12V is applied. I'd prefer the grounded approach from a purely EE perspective - it's more failsafe that way if the wire grounds to chassis you're going to lose boost instead of NOT losing boost and popping the gauge circuits if it's setup as a +12V and grounds to chassis."
Old Sep 22, 2013 | 10:06 PM
"So in the diagram I posted, you would want to probably interface with the primary/reactive boost 2-port solenoid (the brown one). Remember solenoids have no polarity - just like injectors which are solenoids of sorts - so it doesn't matter which wire of the 2 you pick for the wiring modifications, but you do want to probably target the ECU side one and not the +12 V constant line.
In the diagram, the EBC side is the ECU side, and everything else would be the same. "
Old Sep 22, 2013 | 10:11 PM
Disclaimer. I have not done this yet. Please someone confirm this for 100% accuracy. Try at your own risk. Ut_evox is not responsible for anything.
hutch959
Jan 3, 2016 06:04 PM
hutch959
Jan 3, 2016 05:51 PM
Grimgrak
Nov 29, 2013 03:06 AM
saulbyu
15
Jan 21, 2010 11:00 PM
