Sponsored by:
Sponsored by: CARiD
Lowering Springs
Old Nov 25, 2013 | 06:13 PM
Kartyman550's Avatar
Lowering Springs
Do certain brands lower the car more? i saw that the swift spec r only lower by 1.3 and 1.0 inches front and back but is there a company that lowers it more? Also i don't know anything about suspension on cars. Can I just get the lowering springs and swap them out for my stock ones or do i have to do shocks or something too? Do I have to get a wheel alignment or change anything else or can i just slap them on and go?
Old Nov 25, 2013 | 06:46 PM
ImEv0's Avatar
you will need to get an alignment after you swap springs.
generally speaking, yes, you can swap out springs and call it a day. but all you're doing is lower the center of gravity and that's pretty much it. well, depending on the springs, you might also **** with the cars geometry.
what you should do is get good performance springs and get the stock bilstein re-valved. apparently, this combo is good enough for most people. if you want to go all out, go get a nice set of coils.
lower than swift? i think eibach is lower. not sure by how much more...
Old Nov 25, 2013 | 07:17 PM
EvoXE's Avatar
https://www.evolutionm.net/forums/ev...art-evo-x.html
Old Nov 25, 2013 | 07:29 PM
cool thanks guess ill just get the spec r's and call it done.
Old Nov 25, 2013 | 10:37 PM
n52b30's Avatar
i can say the swift spec r's have been great for me
Old Nov 26, 2013 | 06:26 AM
Iowa999's Avatar
Note to self: remind folks that "sticky" is a good thing when applied to threads, as opposed to, say, bed-sheets.
Old Nov 26, 2013 | 09:55 AM
thegoodservant's Avatar
I have swift spec R. Perfect drop for me.
Old Nov 26, 2013 | 10:55 AM
nikmoretto's Avatar
an alignment is no necessarily needed when changing springs...keep that in mind
Old Nov 26, 2013 | 11:48 AM
Iowa999's Avatar
Proof-reading is no necessarily needed, either. tee hee
Regardless of what you were trying to say, an alignment is a must after swapping springs, especially on a car with struts at either end.
Old Nov 26, 2013 | 12:37 PM
ImEv0's Avatar
really??? really?? are you serious?
Old Nov 26, 2013 | 01:13 PM
dw0095's Avatar
I have used Progress Sport springs on my old WRX with stock struts and they provided a very low stance but kept the ride nice. And yes, get an alignment unless you don't mind your tires wearing in all the wrong places.
Old Nov 28, 2013 | 09:22 AM
08wwevoXshane's Avatar
If you want a lower drop and still somewhat good ride quality get h and r
Old Nov 28, 2013 | 09:32 AM
DakMarEnt's Avatar
I used the H&R and swapped bck to my stock spring when i upgraded wheels and tires and the stance seems ok for me.
Old Dec 12, 2013 | 07:10 AM
Jgarcia6820's Avatar
The HR springs are by far the lowest ones. When it comes to height
Old Dec 14, 2013 | 01:36 PM
Afrank97's Avatar
I have swift sports and thinking of going with a bigger drop here soon
