Mitsubishi boost leak test
Do you guys think that the dealer has a boost leak test they would do if I asked them? I thought about doing it myself, but it is beyond what I can do mechanically.
I would think they would have too. What if a stock evo came in exhibiting signs of a boost leak. They would have to find it some way.
I wouldn't let a Mitsu Tech within 200 yards of my car
No they will have no frigging clue what you are talking about I'm sure. Just find a local to help you out or bring your car to a EVO Specialty shop
Boost leak test's are simple. You can hook into the turbo inlet or post turbo ( upper intercooler pipe ). Pressurize the system no more than 20 psi and listen for leaks. You can either buy a tester for about 35$ or make one. I made one but ended up spending about the same amount as the ones you can buy, it was my first time though. Didn't find any leaks in my intercooler or pipes, I heard slight leaking from my cobb bpv.
smoke machines don't work at high pressure
or, OP, you can start the car, then spray a can of starting fluid along the lines where you think there might be a leak. When the engine revs up suddenly, then taht's where the leak is.
[WTB] Evo 8 Throttle Body.
4b11slayer
Dec 31, 2016 01:16 PM
TwoFour
72
Jan 17, 2009 05:44 PM
