Sponsored by:
Sponsored by: CARiD
ASC/ABS Service lights on
Old Feb 2, 2014 | 02:54 PM
Uscbryan's Avatar
I have about 50k miles on a 2012 GSR. This morning when I started the car the warning lights came on. It was fine when I parked it last night. They came on today before the car even moved, just sitting here warming up.
Any ideas?
I installed a Beatrush rear bulkhead panel this morning. Checked to make sure I didn't hit any wiring. Not even sure if there is wiring for that in that area. The pump itself is full.
Thanks
Old Feb 2, 2014 | 04:12 PM
littlezrexer's Avatar
What codes do you have? That would be a start
Old Feb 2, 2014 | 04:49 PM
Uscbryan's Avatar
Not sure. Need to borrow my friends reader. Mine isn't working for some reason. I'll try to do it tomorrow.
Thanks
Old Feb 2, 2014 | 05:28 PM
Iowa999's Avatar
Please note that, if you checked the ACD/AYC fluid before writing "the pump is full," that's probably irrelevant. To lose the ASC and ABS at the same time usually means a wheel-speed sensor or the ABS unit. You won't get those two warnings from a ACD/AYC pump issue.
Old Feb 3, 2014 | 08:17 AM
Uscbryan's Avatar
I'm sorry, I didn't get the first part about checking the resovour?
Old Feb 3, 2014 | 09:14 AM
ChUt26's Avatar
You need to let the car sit on a level surface for at least 6 hours to give you an accurate reading on the reservoir level.
Old Feb 3, 2014 | 09:45 AM
Iowa999's Avatar
I was saying that the ACD/AYC pump reservoir is irrelevant, because ACD/AYC pump issues don't cause ABS issues. If you meant something else by "the pump is full," ignore this and say which pump was full.
But, again, odds are you lost a wheel-speed sensor.
Old Feb 3, 2014 | 11:06 AM
Uscbryan's Avatar
Ok, I was just trying to give as much info as possible. Where would I find the pump and Ecu for this? Where are the wheel speed sensors located?
The resivour in the trunk is full.
Thanks
Old Feb 3, 2014 | 12:10 PM
Iowa999's Avatar
This is not something to diagnose by looking at stuff. This is when you go get the code read.
Old Feb 3, 2014 | 04:28 PM
Uscbryan's Avatar
No codes on my OBD. Guessing I need to have a dealer specific reader.
The reason I want to look at the sensor is the right front fender liner being ripped out at high speed may have hit it. And on the left I had an issue with a guard rail in the canyons last month.
Can't hurt to visually inspect them.
Old Feb 3, 2014 | 05:08 PM
Iowa999's Avatar
Ah, yes. If the wire is cut, that would be obvious. And, yes, you need a code-reader that's a bit better than a Pep-Boys typical. MUT or EvoScan or, I believe, AccessPort will all work.
Old Feb 3, 2014 | 08:42 PM
Uscbryan's Avatar
Cool. Taking it to a shop Friday. Was planning I having fluids changed anyways. Hopefully they can fix it track day in a few weeks. Would be old school if I have to go before it's fixed.
Old Feb 10, 2014 | 09:51 AM
Uscbryan's Avatar
Had the dealer pull the codes.
DTC P0219
C102B
C1035
Appears it's the RR wheel speed sensor.
Old Feb 11, 2014 | 04:26 PM
Uscbryan's Avatar
I fixed it. Appears when I installed the beatrush bulkhead panel I pinched the wires. Once I lifted the panel off the wires the ABS/TC service lights went out.
Old Feb 12, 2014 | 09:59 AM
ikt's Avatar
ikt
yeah there's a harness that runs on each side
