Sponsored by:
Sponsored by: CARiD
quick help
Old Mar 2, 2014 | 07:43 AM
newevoxguy's Avatar
quick help
So I just installed a fmic upper and lower ic piping and a synapse dv. Im getting a little studder/buck in second and third gear not all the time but still annoying is this from the dv its set up in push and a and b port
Old Mar 2, 2014 | 12:02 PM
Treyzian's Avatar
Tune? Are you getting the stutter at low RPM, part throttle?
I was a little confused by what you meant with "dv its set up in push and a and b port."
Old Mar 2, 2014 | 12:14 PM
newevoxguy's Avatar
Yes I am just like that
Old Mar 2, 2014 | 12:50 PM
newevoxguy's Avatar
And I have a cobb ap I get tunned april 1
Old Mar 2, 2014 | 01:03 PM
blusubman's Avatar
i would talk to your tuner about the issue. make sure your dv is fully closed on idle could be you didn't put it on right. tuner should be able to fix that for you.
Old Mar 2, 2014 | 01:27 PM
newevoxguy's Avatar
So if I put the stocker dv back on ill be fine and just wait til I go to get tuned
Old Mar 2, 2014 | 02:11 PM
Treyzian's Avatar
You're fine. The stutter at part throttle is normal, especially in higher gears. The change in intercooler piping may have exaggerated it a little, but it should be fine. Just make sure your synapse is set to full recirculation and not vta (atleast until you talk to your tuner).
Old Mar 2, 2014 | 02:44 PM
newevoxguy's Avatar
Ok thanks guys
roidz3
Nov 3, 2015 08:15 AM
newevoxguy
Feb 2, 2014 11:27 AM
Noe18
Jan 19, 2014 08:07 PM
Noe18
Jan 11, 2014 07:51 AM
