Sponsored by:
Sponsored by: CARiD
Downpipe removal - bolt broke off
Old Apr 26, 2014 | 08:27 PM
beetle_orange's Avatar
Need suggestions on how to proceed. Need to know how to extract the rest of the bolt that was left behind.
To those that have removed the downpipe, I broke the one bolt closest to the engine, it's the one bolt directly above 1 of the 2 bolts that are accessible through the passenger wheel well.
Really need ideas.
Sadly car is an 08 with only 20k miles....
Old Apr 26, 2014 | 09:44 PM
mlouis's Avatar
maybe a left hand drill bit? i've never come across this issue myself but it might work
Old Apr 27, 2014 | 02:38 AM
Treyzian's Avatar
Damn that's low miles.
Honestly, I take broken/snapped bolts to shops as it's relatively cheap, and the headache is just not worth it.
Old Apr 27, 2014 | 10:46 AM
Gqracer's Avatar
U will probably need to remove the exhaust manifold and the turbo. You need a special carbon etc material bits to drill it out. Best thing is to take it to a machine shop and have them drill it out. I experience the similar problem also. I broke the stud on the driver side o2 housing. I end up taking the exhaust manifold and the turbo off and had a machine shop drill out. They even put in a new stud also. Best of luck.
Old Apr 27, 2014 | 07:09 PM
Johnr352's Avatar
I suggest a good local shop. They will have the right tools and experience. It can be quite a pain. It's a hassle to get the car there. Hopefully you can just put the other bolts back in and drive it over...
Old Apr 27, 2014 | 09:05 PM
GSRSTIKILR's Avatar
Veteran: Army
+1 on bringing it to a shop. Not worth the headache
Old Apr 28, 2014 | 05:16 AM
PBX's Avatar
PBX
your alot better off bringing it to a local shop, other than that the only other real option you have would be a tap and die set but i feel like that would be a pain in the *** to get to with one
Old Apr 28, 2014 | 10:32 AM
this is what i am working with
Attached Thumbnails Downpipe removal - bolt broke off-10308370_679837285395687_2850583634435814921_n.jpg
Old Apr 28, 2014 | 10:55 AM
SilverShadow03's Avatar
Either pick up a bolt extractor kit from SnapOn or the likes and give it a shot. Looks like you have enough room from the pic you posted but you will have to be the judge of that.
OR, take it to a shop.
Old Apr 28, 2014 | 06:56 PM
I have removed the 10 nuts on the exhaust manifold and the 2 nuts and 2 bolts that hold the hotside to the exhaust manifold but the turbo still won't move? Any ideas? Took the uicp and 1 bolt on a bracket that holds the turbo but it is still not moving.
Old Apr 29, 2014 | 02:24 PM
sgtr275's Avatar
oil and coolant lines?
Old Apr 29, 2014 | 06:53 PM
Hoping not to go there. I was told there is another bolt under the hotside that holds the turbo after which I should be able to move the turbo and pull the manifold up.
Old Apr 29, 2014 | 07:20 PM
Gqracer's Avatar
There is a bracket with a bolt that the exhaust manifold sits on. You can only access the bolt underneath.
Old Apr 29, 2014 | 07:27 PM
Exhaust manifold or the turbo manifold? The exhaust manifold is loose but just won't go over the 2 studs sticking up from the turbo hotside.
Old May 1, 2014 | 12:05 PM
deanob's Avatar
Same thing happened to me few weeks ago when I did my downpipe.
I removed the hot side from the turbo while still attached (pretty easy) and sent the hot side out to a machine shop to have drilled out and re-taped.
Good luck.
