Sponsored by:
Sponsored by: CARiD
Coilover or lowering spring
Old Apr 28, 2014 | 07:35 PM
Mikeodeth's Avatar
Hi guys.
I bought a set of te's sl with 18x10 +40 size. I was told that i can only use coilovers to lower my car coz the tires (265/40/18 size) will rub the lowering spring if i use one.
Thanks
Old Apr 28, 2014 | 08:14 PM
f-dub's Avatar
That is a horrible wheel size/offset combination to get for an Evo. Did you get a good deal or something?
Old Apr 28, 2014 | 08:24 PM
Mikeodeth's Avatar
Yap a good deal.
Old Apr 28, 2014 | 09:36 PM
Sev's Avatar
Sev
You're gonna need at least 15mm spacers all around to even fit those.
Old Apr 29, 2014 | 12:28 AM
kevinlambchops's Avatar
I would say 25mm spacers. make it look mean! but that is just my opinion and im not even sure if its safe but yeah.. lol I want to get 18x10.5+15. soon.....
Old Apr 29, 2014 | 06:26 AM
chundizzy's Avatar
I have 18x9.5 +15 Enkei Raijins with some 255/40 tires I feel the pain
Old May 1, 2014 | 08:48 PM
IRPerformance's Avatar
You'd want an 18x10 with an offset around +25. The tire size is fine. You could try a spacer to push the wheel out but I would say just sell those and get the right size wheels. I never recommend lowering a car with just springs. The ride quality almost always degrades. Either get a proper shock/spring combo or a set of good coilovers. Personally I run custom valved bilsteins and eibach springs. I'm very happy with the ride and handling. I road race and street drive the car.
Old May 2, 2014 | 12:19 AM
Mikeodeth's Avatar
So if i use coilovers will it work without spacer ?
Thanks
Old May 2, 2014 | 07:18 AM
f-dub's Avatar
Thanks
I'm not sure. I've never heard of anyone going with a wheel size/offset that you have. Hitting the coil is only one issue you might face. The other is that without spacers the spokes of the wheel might also hit the calipers. The only fix for this is to get a spacer (or better yet get properly fitting wheels).
Old May 2, 2014 | 10:58 AM
I think you are going to have an issue hitting either the brake calipers or the shocks. Put it on carefully with the car jacked up and rotate the wheel and see what happens.
Old May 2, 2014 | 07:21 PM
Mikeodeth's Avatar
Thanks guys. Ill post what will happen when i install it nxt week.
Old May 9, 2014 | 06:03 PM
Mikeodeth's Avatar
Hi guys. The wheels fit perfectly on the rear but the front needed 25mm spacers. I lowered it with coilovers.
Thanks
Old May 9, 2014 | 10:08 PM
Pics?
Noe18
40
Aug 22, 2014 10:42 AM
Ledspy
May 23, 2014 01:44 PM
Mikeodeth
May 5, 2014 04:00 PM
Dragking2189
22
Feb 1, 2010 01:02 PM
mirage 4g93t
Apr 7, 2008 07:33 AM
