Sponsored by:
Sponsored by: CARiD
Tpms
Old May 1, 2014 | 09:35 PM
kelogg's Avatar
Tpms
I'm sure that i'll end up getting a tongue lashing for not using the "search" (95% of the time wild goose chase) feature.
I have a broken TPMS sensor thus, need a new one. Does anyone know what sensors WILL work and where I can find them?
Old May 2, 2014 | 03:33 AM
Sawdust's Avatar
I'm sure NGS can help you. Don't throw out the broken one, he'll probably need the code from it.
See thread https://www.evolutionm.net/forums/ve...your-dash.html
Old May 2, 2014 | 08:14 AM
Veronica's Avatar
What broke?
If it is the stem - there is a replacement kit (and any tire shop can fix without having to go to the dealership to have a brand new one synched... )
Old May 2, 2014 | 09:35 AM
4EverWiKiD's Avatar
Veteran: Air Force
It wasn't on an evo, but I had a sensor go had and it was covered under the warranty.
Old May 2, 2014 | 09:41 AM
kelogg's Avatar
I didn't think about keeping it. It broke broke about 4 months ago when I had my snows put on. So they tossed it.
Old May 5, 2014 | 07:59 PM
Evo_Xela's Avatar
I work at Discount Tire. A buddy of mine broke his sensor on his lancer when installing new wheels #fail. and at the time we didnt have any compatible ones. He ended up having to buy one from the dealership for the same price as one of his rims :/
Old May 5, 2014 | 08:01 PM
Evo_Xela's Avatar
What i can do I can check tomorrow at work and see if theres any compatible ones out now. If there is they run about 60 bucks.
Old May 7, 2014 | 09:23 PM
kelogg's Avatar
That would be great, if you didn't mind.
Old May 8, 2014 | 09:22 AM
Veronica's Avatar
I see them on ebay all the time...
Old May 8, 2014 | 04:27 PM
kelogg's Avatar
Haven't thought of checking there either....good call.
Old May 9, 2014 | 05:14 AM
Evo_Xela's Avatar
Discount tire does have them. You can get it for 60 bucks installed and programmed
Old May 9, 2014 | 02:33 PM
kelogg's Avatar
I've heard mixed things about discount tire. Some work, some don't. Might be worth checking it out.
Old May 9, 2014 | 06:51 PM
packrat's Avatar
Where in ny are you? If you don't have your old sensor then cloning might be tough. The programmed id numbers can be retrieved from your car with a scantool. Worse case scenario is just have the dealer reprogram for $30.
Old May 10, 2014 | 03:43 PM
kelogg's Avatar
I'm located in Palmyra. about half way between Rochester and Syracuse. I'm starting to think maybe just going to a dealer for a new TPMS and to have it programmed might be my best bet. Not having a TPMS isn't bad, it's just the annoying light on the dash that is annoying.
Old May 10, 2014 | 08:52 PM
sw2oboi's Avatar
Only option for you now is to buy a new/used tpms sensor and have it programmed to the car.
