Sponsored by:
Sponsored by: CARiD
Leaky BOV cause issues even if recirculated?
Old May 9, 2014 | 08:35 PM
CtSilver03Evo's Avatar
My car is having on and off symptoms of power loss lately. I've noticed that when going through the car when I removed my Forge BOV that when I blow into it, the air goes right out. If I play with the piston in it a bit, it will seat properly sometimes and not leak at all.
If this was happening while driving, would this contribute to the car running poorly from time to time (laggy spool, not as high of boost, etc...)? Overall the car feels a lot slower when this happens. The BOV is recirculated back into the intake, so it's not losing any meter air from the MAF, but I would guess there would be some form of pressure drop there. Anyone know for sure?
Old May 10, 2014 | 04:48 AM
ravenjam's Avatar
If your BOV does not seal correctly and therefore leaks, it would most definitely cause performance issues. Even though you are recirculating, you would be bleeding off pressurized air. You should replace that valve. Contact forge and see what they can do for you.
Old May 12, 2014 | 02:31 PM
ikt's Avatar
ikt
doesnt matter if it's leaking into the atmosphere or leaking into your intake pipe-it's still leaking!
Old May 12, 2014 | 08:38 PM
IRPerformance's Avatar
Not to mention your turbo will have to work harder to try to make the same boost it is losing. I would upgrade the bov. There are plenty of good ones on the market (Turbosmart, Synapse, etc)
Old May 13, 2014 | 09:07 AM
Veronica's Avatar
(or just put the OEM one back on if you are at near-stock boost levels...)
Old May 14, 2014 | 10:47 AM
Ralli04Art's Avatar
Yes it can still cause issues if its leaking
If you have an vein leak in your body and not bleeding out, youre still bleeding internally and theres an issue lol.
clanzkiller
Mar 16, 2017 07:13 AM
Careyalfie
Jan 11, 2017 06:42 PM
15evotuner
Aug 22, 2015 05:40 PM
freefoodnow
Sep 12, 2013 10:48 AM
vegeta irie
Jun 23, 2005 04:33 AM
