Installed ETS UICP and now have a major boost leak
So I installed the UICP and checked that everything was tight and all the clamps were tight well went to take it for a spin and I could hear the boost escaping and could feel it losing power. Here are some pics I took of the couplers. Anyone see anything wrong or have an idea? Thanks!
Well I loosened the Air inlet coupler and pushed it down a little more then re-tightened it. Also loosened up the mid section and made sure the clamps were on the edge past the seals and re-tightened. Boost leak is still there so I need to check the coupler at the IC pipe but have to take the cowling off again. What a pain in the *** this is turning out to be!
Yea it is a pain. Mayb check that the bolts are tightened alittle more and maybe the intercooler coupler might not be on as tight as it should be. That one can b a pain to do with the front bumper still on.
Well I think I fixed it. I repositioned the coupler at the IC inlet and made the T-clamps super tight. Theres about .5 inch of thread showing on the screws now as to .25 before. Still wondering why the ETS coupler is about 1/4 inch shorter than the stock ones. Car pulls stonger now but still hearing some slight whoosh sound at higher RPMs. What a pain in the *** though. Had to go get a deep 11mm socket and a swivel to help make it easier. Also removed my horn from the bracket. Gonna have em check it over when I get tuned cause Im paranoid theres still a slight leak
separate topic for my 9's LICP, clamps on but must be a leak somewhere. I'll check if mine are on a pipe bead, but what of it? could air be escaping through there?
I had that same issue, removed my bumper so I could get at it better, and was able to re-position everything so that it all fit just right and tightened it all down. I know that all the install guides out there say you dont need to remove your bumper to do the UICP, but I definitely recommend doing it for simplicity and less frustration. Takes like 15 minutes to take it off to once youve done it once.
Check the coupler to the intercooler inlet. That was my problem.
I also noticed on my t-bolt clamps, I had a lot more threads showing then you. the t-bolts should be compressing the silicon coupler, if not, they are not tight enough.
