Sponsored by:
Sponsored by: CARiD
Recently Purchased Evo x error help
Old Feb 16, 2015 | 08:51 PM
dharmeshp's Avatar
Question Recently Purchased Evo x error help
hey guys i recently purchased my first evo x and i'm getting the error with the front two wheels turned and says service engine soon. just curious on what could cause this and if its something i can drive around with as i'm kinda broke for a little while. i also dont know if the weather is a issue but recently its been around 5-17degree F if thats any help.
PS: please forgive me if this isnt where iam supposed to post this is my first time posting.
Old Feb 16, 2015 | 09:19 PM
BlackHawk_Tsi's Avatar
what do you mean with the front wheels turned? do you mean when you are turning corners while driving or parked and turning? turning left or right?
can you pull your codes? autozone does it for free.
Old Feb 16, 2015 | 09:22 PM
dharmeshp's Avatar
I mean the error has the picture of the chasis with the front wheel turned like a awc error.
Old Feb 16, 2015 | 10:04 PM
Napalm_Enema's Avatar
Check your brake fluid level.
Old Feb 17, 2015 | 05:09 AM
dharmeshp's Avatar
im probably going to have all my fluids checked and replaced. The dealer probably cleared the errors before selling the car to me. If that's true ill post on the new buyers forums to avoid this dealer for future buyers. but until i confirm whats wrong, and whether its just minor or major problem and hope it wont cost me an arm and leg to fix .
Old Feb 17, 2015 | 05:20 AM
lancerus's Avatar
Maybe the ayc/acd pump is gone? Go back to the dealer and have it replace under warranty.
Old Feb 17, 2015 | 05:27 AM
Good answer! Good answer!
Old Feb 17, 2015 | 07:29 AM
dharmeshp's Avatar
ok so assuming its a ayc/acd pump problem what type of cost am i looking at to replace/repair it? and is it fine to just drive around without it functioning because on other forums ppl say that its fine to not have it working just dont remove it. i will also go to autozone today and pull a code and while im at it probably just purchase a decent obd2 reader so any recommendations?
Old Feb 17, 2015 | 09:12 AM
They just released a warranty for those (extended) directly from Mitsubishi, so it should be free if that is what is not working.
Old Feb 17, 2015 | 02:11 PM
elkazX's Avatar
10yr/100k mile warranty. so as long as you arent over 100k miles you can get it replaced for free if thats what is causing the problem.
Old Feb 17, 2015 | 06:11 PM
dharmeshp's Avatar
ok, so i pulled the codes i got P0365, P0300, P0037. Dealer is paying to get the car tuned on a dyno sometime next week just need to get an appointment so i'm glad its not the AYC pump at least. do you think a tune would fix those issues though?
Old Feb 17, 2015 | 08:59 PM
ChipperEvo's Avatar
The dealer is dyno tuning your car to fix transmission error codes? Wat?
Old Feb 17, 2015 | 09:03 PM
dharmeshp's Avatar
Before buying the car we had a deal to get the car tuned to my choice since he works closely with a tune shop and so he told me to bring the codes I pulled with me to the shop on the scheduled day to have them fix it. Now I'm not familiar with this so would a proper tune fix all or any of these codes?
Old Feb 18, 2015 | 05:40 AM
It could be a tune. There's a part in there for obd2 modifications.
P0365 - Camshaft Position Sensor 'B' Circuit Bank 1
P0300 - Cylinder Misfire Detected Random Cylinders
P0037 - HO2S Heater Control Circuit Low Bank 1 Sensor 2
Does it drive rough? Could be a regular repair needed.
Old Feb 18, 2015 | 06:12 AM
dharmeshp's Avatar
well rite now it feels like when ever i drive up to 2-2.5k rpm its normal but then it starts to feel like i lost power then kicks back into normal which im assuming is due to not having a proper tune and the fact that theres a misfire error. so i guess you can say it is rough but i wouldnt count out the fact that i come from driving a 05 wrx and so this would be a big step up and im still not fully used to the car yet since its got pretty much a stage 2 setup... ill try to get a full spec list for you guys from the dealer so you have a better idea of what its got. but regardless of how much work it needs rite now i must say the thrill and amount of fun i have just cruising around in this is just to good to explain hahaha i wonder what it'll feel like after i get it fixed and proper .
