Sponsored by:
Sponsored by: CARiD
Cat heat shield
Old Jul 17, 2015 | 11:36 AM
evoxsteez's Avatar
Cat heat shield
Will removing the heat shield that's wrapped around the cat cause any problems? I had to open it in half to bolt up my new exhaust and now it rattles like crazy all the time. Test pipes don't have any shields around them so I wouldn't think it would cause problems but does the cat typically get hotter than a test pipe? I suppose I could also put a large clamp around the shield and tighten it down so it wont rattle. In case it still does, removing the shield would be my only option.. or a test pipe but don't want that just yet.. Car has only 8k miles.
Old Jul 17, 2015 | 11:52 AM
hoobastnk90's Avatar
You can just remove the heat shield it will be fine. One thing though is that the heat shield itself is a bit of a pain to remove you may be better getting out a hammer and try bending it whereever it is rubbing. Thats what i did when i first got my exhaust b4 i got my high flow cat. And it seemed to work fine.
Old Jul 17, 2015 | 12:49 PM
e_kobz's Avatar
I removed mine back in the day. You'll be fine.
Old Jul 17, 2015 | 12:51 PM
obake214's Avatar
Yeah I don't see a real big issue with removing it. cats might run slightly warmer but shouldn't affect anything. Im running a test pipe so removing it I would listen to hobbastnk
Old Jul 17, 2015 | 06:26 PM
Viegasjuice's Avatar
Unhappy
Mines gone too.
kuya7888
Mar 18, 2015 05:57 AM
evo8tp
Oct 19, 2010 07:59 PM
Mitsu3
Feb 12, 2007 03:07 PM
zstryder
May 27, 2005 07:08 AM
