Sponsored by:
Sponsored by: CARiD
Weird FAST key problem - Car always thinks key is present?
Old Sep 17, 2015 | 08:12 AM
gizmotoy's Avatar
So I've searched through the FAST threads I could find, but couldn't find anything like this. My X seems to have glitched into a state where it always thinks the key is present. The doors will not lock using the buttons on the handles or the keyfob. If I look through the window it says "Confirm Key Location" like it would when you've left the key in the car, but I'm holding the key and the spare is in a drawer at home.
I've manually locked it using the metal key for now. Any thoughts? Is there a "reboot" procedure to try? Just pull the 12V battery for awhile and see what happens?
I generally try to avoid the dealer, but seems like I have a decent chance of needing a trip with this.
Old Sep 17, 2015 | 08:41 AM
AlexDRS94's Avatar
That's what I would do. Just disconnect the battery and let it sit for a few minutes and try again
Old Sep 17, 2015 | 09:27 AM
gizmotoy's Avatar
I was doing some testing and found the car would start even without the key inside, which made this a bit higher priority than I otherwise would have liked. I took a break from work to head out and pull the battery for a bit. After reconnecting, the system seems to be functioning normally again.
Really, really strange, but at least the fix was easy. Thanks!
Old Sep 17, 2015 | 12:12 PM
Napalm_Enema's Avatar
I was going to suggest blowing up the car and defrauding insurance, but this was a much better and faster fix.
SOUNDWAVE333
Evo X How Tos / Installations
Feb 7, 2014 03:57 PM
BMWE30
Dec 16, 2006 09:23 AM
dxbevo9
Dec 8, 2006 09:06 AM
Az3ar
68
Mar 27, 2004 08:18 PM
