Sponsored by:
Sponsored by: CARiD
Help Guys
Old Nov 20, 2015 | 11:33 AM
ilviolatorli's Avatar
Help Guys
Hi guys im still super new to the evom forums. Last night I installed my ETS fmic, and ETS uicp and seemed like everything was fine. Ran the car this morning to test it out,, and now I get this noise coming from the engine bay like hose came off or even sonds like I have a Bov, the car is completly bone stock also car has no check engine light on or anything but just something doesn't feel right. Maybe I wasn't suppose to add this on a stock evo x.
Old Nov 20, 2015 | 11:59 AM
jakgal04's Avatar
Can you go back and double check to make sure none of the hoses popped off? Theres a lot of clamps involved in the work you did so they may not have been tight enough. Also, You should really be careful about throwing mods on without a tune, you can break things.
Old Nov 20, 2015 | 12:27 PM
shekaar's Avatar
Check for a boost leak, loose connections first. Not sure what you mean by sounds like you have a bov, is your stock one just more audible? Replacing the stock rubber UICP with metal will make some of the car noises more audible, that's normal.
Old Nov 20, 2015 | 12:31 PM
Went back checked all clamps and all of them are still on and securely tighten down.
Old Nov 20, 2015 | 12:35 PM
shekaar I want to say your right. That's exactly what it seems like. Seems like the stock bov is more audible, just wasn't sure it that wad suppose to be normal. I checked all clamps and cheked for boost leaks and found nothing wrong. Car is spiking @15 pouds of boost and holding is that normal? The reason I ask is because before any mods it used to spike around the 20ish area and hold at 15. Thx for the help
Old Nov 20, 2015 | 12:52 PM
FernieB's Avatar
Its normal... with the FMIC you added more airflow.
Old Nov 20, 2015 | 01:14 PM
Thx for the help bro!
Old Nov 20, 2015 | 01:31 PM
shekaar's Avatar
Yea I'd get a tune, not that running UICP and a FMIC is going to cause tons of issues on a 2012 without one, but you're doing yourself a disservice modding without a tune.
Old Nov 20, 2015 | 02:13 PM
Like a professional tune or is there a way I can get away with it with just an AP, since full bolt ons is the direction im going for. I also purchased a grim speed EBC when should that come in play?
Old Nov 20, 2015 | 02:55 PM
AngryEvo's Avatar
This is stuff you need to research before you buy and install. You cannot use that ebc with a Cobb map....
Old Nov 21, 2015 | 05:36 AM
Johnr352's Avatar
Please get a professional tune. Build a relationship with a good shop. Your experience with the car will be MUCH improved...
04Evo851374
Apr 9, 2013 06:15 PM
E VOL IX
Northeast Region
36
Jun 8, 2008 08:37 PM
blackevoVII
Turbotrix Racing - Edison, NJ
Nov 2, 2004 10:23 AM
