Sponsored by:
Sponsored by: CARiD
ETS Intake NOT compatible with aftermarket BOVs?! I need Help Installing a BOV!
Old May 31, 2016 | 02:13 PM
TxFAkuma's Avatar
Originally Posted by ETS Michael
33mm is the size GFB notes. It should be part# GFB5333 and GFB5233 for the inlet and outlet adapters.
- Robert
Thank you for the information. I couldn't find the outlet adapter on the GFB webpage because the part # for the outlet only went up to 5230 (30mm) so i will purchase it from ExtremePSI.
Thank you all so much. It's important not to have any leaks
Old Jun 6, 2016 | 03:56 PM
TxFAkuma's Avatar
Update:
Adapter worked flawlessly!!! No leaks, no compression surge, sealed air tight! I only used the "inlet adapter because the outlet was the same size as the bov's outlet already. Thank you for the links!! I am 100% satisfied lol
Old Jun 6, 2016 | 04:13 PM
ETS Michael's Avatar
Glad to hear it.
- Robert
Old Feb 17, 2020 | 10:12 AM
HoodieWeather's Avatar
5 Year Member
I was wondering what BOV would be able to be used with the ETS. seems like only a few companies will work. I did get in touch with someone from MAP about the Greddy BOV
https://www.maperformance.com/produc...-cz4a-11531211
From what I told this rep was I have the ETS intake installed and i shot a pic and sent it, and he came back and said that this BOV will work with my intake.
"Hello
This will work it comes with 34mm adapters to adapt to the up and lower recirc pipes.​"
I still don't believe it will work for some reason. I could be wrng.
03redtype-s
Oct 17, 2015 06:02 PM
evo jason
Apr 21, 2013 02:56 PM
slowbaru
14
Apr 24, 2012 07:53 AM
slowbaru
16
Apr 24, 2012 07:49 AM
High_PSI
Oct 20, 2010 07:22 AM
