Finally pulled the trigger on an Evo X
Normally, no. They can be made to do so depending on how you adjust your fuel and timing maps. It's not recommended, but if you must do it, do it only on a test pipe exhaust with no catalytic converter to burn up.
-pal215
-pal215
Can anyone tell me about this body kit or company products in general? http://www.bodykits.com/i-24222633-m...tegory:1248663
There's just no way I can afford 4-5K on a varis kit
Hey guys, I've been fighting a check engine light for days now, pretty much since I bought the car now. The first code was for the cat being under threshold or something like that. So I bought non foulers and installed both from the package on the rear 02 sensor like in the picture above. Cleared all codes and a day later, today, and I get the p0171 too lean code. Did I do something wrong, or do I have another issue?
How much are the e-tunes usually, because these are my only option? I'm not really prepared to have to buy the data logger....
What will happen if I leave it like this for a bit until I can get it fixed? I have a OBDII scanner to clear it. Would that help or make it worse?
wtftuned.com , 5150 Racing, kozmic motorsports all do etunes I believe.
your car has a factory aero kit...unless the the scratches and scuffs are huge I would just give the car a thorough detail, (clay, polish, wax) before you go buying any body kit. You are going to slap some after market kit over the nice OEM one. The factory aerokit you have looks really aggressive once you drop the car and run some wider wheels. This way you can focus your money on getting rid of the CELs and getting the car to run right. Bodykits rarely fit 100% and unless you got someone you know in a body shop it will cost some money to put them on just right. My 2 cents.
