Sponsored by:
Sponsored by: CARiD
2015 Evo Recall
Old Oct 19, 2017 | 01:01 PM
DBomb117's Avatar
2015 Evo Recall
Anyone Know about this? I saw something about a supplier making a faulty relay that can kill your ECU leaving you stranded on the side of the road or something of the like. Is anyone aware of this notice or had it replaced yet?
Old Oct 19, 2017 | 01:15 PM
EVOX84's Avatar
Never heard about this nor have i seen anything out there about it
Old Oct 19, 2017 | 01:27 PM
splattj's Avatar
Old Oct 19, 2017 | 03:18 PM
DBomb117's Avatar
Got this notice
Old Oct 20, 2017 | 05:45 AM
splattj's Avatar
Mitsubishi has had an awful time with Omron and their relays during this car's production! Nothing huge to worry about but you should call the dealer to get it scheduled for repair.
Old Oct 23, 2017 | 01:57 PM
maverick53's Avatar
are these the same or different relays everyone says to upgrade to? as a 2015 owner, do I need those blue or green relays?
Old Oct 23, 2017 | 07:25 PM
fafaforza's Avatar
No this looks to be a different relay issue.
Anyway, you can look up your own car at
https://www.mitsubishicars.com/owner...e?q=recallinfo
My 2015 X is on there.
Old Oct 28, 2017 | 01:34 PM
ApexPredator's Avatar
so this isn't the fuel pump relay?
Old Oct 29, 2017 | 06:12 AM
fafaforza's Avatar
"IF THE RELAY FOR THE ENGINE CONTROL UNIT FAILS, THE ENGINE WILL STALL WHILE DRIVING AND CANNOT BE RESTARTED.
IF THE RELAY FOR THE ENGINE VALVE LIFT CONTROL FAILS, THE ENGINE WARNING LAMP WILL ILLUMINATE AND FAIL-SAFE MODE WILL BE ACTIVATED, LIMITING AVAILABLE ENGINE POWER.
IF THE RELAY FOR THE RADIATOR FAN FAILS, THE ENGINE COOLANT TEMPERATURE WILL RISE, THE COOLANT TEMPERATURE WARNING LAMP WILL ILLUMINATE, AND THE ENGINE MAY OVERHEAT."
Don't know if that's an exhaustive list but that's what the text of the recall lists.
Old Nov 5, 2017 | 08:21 PM
CaptainCrunch's Avatar
Thanks for that link... was going to ask where I could check for myself if there was a recall. Mitsubishi service is horrible.
Old Nov 6, 2017 | 08:32 AM
jkane's Avatar
i had my relay replaced when the car was tuned? do they check for that or can i still get a new one? maybe ask for it and replace it myself?
Old Nov 6, 2017 | 12:08 PM
Chef-j's Avatar
Which relay you replaced? You can still ask for recall and they will replace it for you.
Btw i got mine done last week. 30 mins in/out with multi inspection and free wash lol
Old Nov 7, 2017 | 08:01 AM
EVOX84's Avatar
i have been watching for my VIN to pop on the website however it still has not. Does anyone know if it takes time for them to get the all loaded? I have a 2015 and i notice that the car always feel different every time i drive the damn thing! Not sure if this could be why or not
Old Nov 7, 2017 | 08:47 PM
fafaforza's Avatar
I also got a physical letter, and mine comes up on their site. I'd say wait another week or three. If still nothing then you should be in the clear.
You could also go to the dealer, they should be able to pull the fuses and tell if they're a faulty part number. Maybe even call Mitsu directly and ask how to identify the bad relays.
Old Nov 15, 2017 | 02:26 PM
loopin10's Avatar
Got mine replaced under recall took 5 mins.
