Should I tow the Evo to the Tuner Shop?
So after doing a lot of reading I have decided its time to put my plan into action. In the near future(hopefully by late March early April) I will be upgrading my daily driver with the following:
MHI Turbo
Turbo Back Exhaust System
3.5" intercooler+lower & upper piping
Intake System
3port Boost Controller
BPV
1300cc Injectors
Fuel Pump
Access Port
I have the confidence in installing all these parts myself, however I will need to get the car tuned.
Should I tow the car to the tuning shop after setting up an appointment, or should I download a tune from Cobb and then take the car to the shop?
Alternatively, should I install everything except fuel pump, injectors and intake then have the shop install those parts when they go to tune?
This would be my first time getting a car tuned and would hate to install all the parts, turn the car on and have it die.
MHI Turbo
Intake System
BPV
1300cc Injectors
Fuel Pump
Access Port
That's a lot of changes, especially with an MR. I'd slap on most of the parts that make sense then have them do the rest. If it were me I'd tow it after putting on the majority of the larger parts.Hope you're going to Kozmic since you're in Texas! They are THE BEST with the MR.
If I were you, I would not entertain these aggressive mods on a daily driver. A dead daily means inconvenience and sad days. The stock 4B11T can handle bolt-ons, but generally it cannot reliably handle an injector upgrade, a fuel pump upgrade, and a turbo upgrade together. For such a set up, some highly talented tuners have been able to keep the torque peak at 4,000~5,000 RPM down and tamed, but these are not common cases.
Also, I think modding cars should be treated as a hobby, which means you play the game when you have excessive cash to burn. (In which case I would not care too much to pay the tuner to install all the mods.) It is important that you have significant cash reserve, so if something gives, you can quickly fix the car back to the road.
r3dtr1ckz
51
Jan 11, 2015 09:46 AM
_des_
Southeast Region
Jan 26, 2010 11:39 AM
