Sponsored by:
Sponsored by: CARiD
Lean Throtle Tip In
Old Jan 30, 2018 | 07:24 AM
sleandro's Avatar
Lean Throtle Tip In
Hello guys,
I'm running ID1000's, DW65C pump, Evo X IC and its hard pipes, AMS high flow cat and 3'' catback. Tuned for e100 with grimmspeed ebcs.
I'm having issues with my 2012 RA. When I tip in (40% TPS even on Neutral from Idle and also running), I'm having lean condition for about 0.3 seconds (17AFR). The fuel trims are pretty on target (+-1%), MAF and MAP tables are still stock.
Nothing seems to respond: I've tried asynch enrichment, load accel enrichment (I'm not 100% sure the addresses are correct, but it seems to) and... nothing.. nada.. zero changes. The car have the same behavior on 100% open loop or closed loop.
WOT is fine and spot on.
I'll attach some logs as soon as I can. But anyways, advices needed until then.
Thank you!
ROMID 58640002
Last edited by sleandro; Jan 30, 2018 at 07:26 AM. Reason: forgot to tell my ROMID.
Old Jan 30, 2018 | 09:04 AM
sleandro's Avatar
Here's tip in log from idle
Fast Tip in from idle.
Originally Posted by sleandro
Hello guys,
Thank you!
ROMID 58640002
jtbell86
11
Aug 1, 2020 09:23 PM
daasca
Mar 14, 2013 10:28 AM
AnthonyB
Aug 25, 2011 08:50 AM
MR. Tim
Apr 9, 2008 10:10 AM
evovin
Feb 1, 2008 11:38 AM
