Sponsored by:
Sponsored by: CARiD
AFRs reading lean...
Old Jul 25, 2020 | 03:08 PM
WW13GSR's Avatar
As the title says, my AFRs are reading lean (via AEM UEGO wideband gauge) showing 12+ at WOT (basic bolt on car tuned on 93 octane). I didn't have time to install my AFR gauge before getting tuned, so the weekend after my tune I went ahead and installed it only to get lean readings. Considering I was just tuned, I figured there was no way that was possible and I messed something up in my install or had a faulty sensor. Now I'm starting to question whether that's the case. So far I've done the following:
Replace AEM wideband sensor
Ensure ground wire has a clean ground
Replace fuel pump relay
Replace gasket between test pipe and stock downpipe and check for leaks (my wideband sensor is in the test pipe so I figured if there's a leak at the test pipe/downpipe connection it would lean out my AFR readings)
FPR hose is ziptied down
Something strange I've noticed is when regrounding the AFR gauge, I unplugged my battery to do so and after that I was getting normal ~11 AFR readings at WOT. After driving for a while and letting car relearn fuel trims, AFRs were eventually back in the 12s at WOT. This leads me to wonder - I installed my boost gauge a week or 2 before getting tuned and had done the same process of unplugging battery for the install. Is it possible my car had not relearned fuel trims before getting tuned and the trims didn't settle until after? I was tuned by a very reputable tuner for what it's worth.
Appreciate any insight/suggestions. I want to sort this ASAP
Old Jul 25, 2020 | 03:18 PM
RazorLab's Avatar
Any tuner worth their beans would turn off fuel trims affecting WOT fueling.
Sorry to hear
Old Jul 25, 2020 | 03:45 PM
WW13GSR's Avatar
Sorry to hear
Thanks for the insight. Like I said my tuner is very reputable and if that’s the case then I’m sure he did.
With that said, do you have any suggestions for what steps I should take next? I’m pretty dumbfounded at this point and it’s driving me crazy
Old Jul 25, 2020 | 03:48 PM
RazorLab's Avatar
If your wot afr is affected by your fuel trims, than they didn’t change that in the tune.
from your description, that is what’s happening.
Old Jul 25, 2020 | 04:12 PM
WW13GSR's Avatar
Disappointed to hear that. So essentially I need a retune..
If I had a tactrix cable and EcuFLASH is this something I could fix relatively easily or would it be a **** show for someone with no tuning experience?
Old Jul 25, 2020 | 08:23 PM
WW13GSR's Avatar
Well you peaked my interest with this and I wanted to verify. I just disconnected the battery to reset fuel trims and took it out for a drive after. Sure enough AFRs in the 10-11s in 3rd gear WOTs, 11s in 2nd gear WOT.
So is my car essentially only properly tuned on fuel trims that are unlearned to my ECU? And when the ECU relearns fuel trims it leans it out? AKA my tune is ****ed? What a mess..
XTR Performance
Evo 'For Sale' Electronics / Lighting / Audio
322
Jun 5, 2013 08:19 AM
GetPowerHouse
28
Oct 10, 2012 11:43 AM
XTR Performance
EvoX 'For Sale' Electronics / Lighting / Audio
71
Aug 30, 2012 10:53 AM
XTR Performance
19
Aug 22, 2012 08:33 AM
XTR Performance
Jul 9, 2012 10:17 PM
