Sponsored by:
Sponsored by: CARiD
Evo X Massive Oil Leak Yesterday, Nothing Today
Old Jun 15, 2023 | 01:04 PM
TurboTJ's Avatar
I started me 2015 Evo X FE for the first time in 4 months yesterday and it had a massive oil leak. Probably half a quart in the 5 minutes it was running. I jacket it up this morning, took off the pan to access the filter and drain plug and it was flooded with oil. I cleaned it off and started the car and I have no drips of any sort. Let it run for 20 minutes and nothing. Has anyone else ever had this happen?
The car has never leaked any oil before yesterday. Any ideas? I’m going to drive it around the block and see what happens.
Old Jun 15, 2023 | 01:14 PM
RobbieOh's Avatar
5 Year Member
Hopefully it wasn't your trans or t-case..
Old Jun 15, 2023 | 01:21 PM
TurboTJ's Avatar
It came from the passenger side so much that my passenger side front tire went through the puddle when backing out of my garage. It appears to be near the oil filter. I am wondering if I could have left the old gasket on when I replaced it in January. Just don’t know why the leak would go away so abruptly.
Old Jun 20, 2023 | 10:47 AM
ugakirk's Avatar
I would just change the oil again and check the filter. Definitely odd.
It was oil though correct? Not gear oil?
Old Jun 20, 2023 | 12:34 PM
ViciousLSD's Avatar
maybe dipstick o ring
Old Aug 28, 2023 | 11:39 PM
TurboTJ's Avatar
In case anyone else has the same issue, it looks like the K&N oil filter was the source. Apparently you are not supposed to use the hex nut on the end for ANY tightening, only loosening.
I’m guessing I used the nut to tighten it, which deformed the shell of the oil filter causing it to leak. Lesson learned.
Old Aug 29, 2023 | 08:28 AM
RobbieOh's Avatar
5 Year Member
Thank you for following up on your thread!!
uaevoVIII
Mar 27, 2012 01:13 PM
ProudEvo8Owner
Oct 7, 2011 09:26 AM
def1
Feb 18, 2010 12:13 PM
702RSevo
Oct 15, 2006 07:56 PM
number 8
May 27, 2006 05:37 PM
