HP rating for built motor
Hello, recently got my motor built. I’m looking for some insight on Hp range I should be looking at realistically. Setup is
Darton wet sleeves
Manley turbo tuff I beam rods with arp 2000 studs (14409-4)
Manley 10.0:1 pistons 86mm bore (614100C‑4)
Gsc s2 cams
Gsc beehive springs and retainers
Efr 8374 turbo kit
Walboro 450 in surge tank 265 in tank
Fic 2150 injectors
4 bar map sensor
Engine specs are
Piston to wall .0026
Top rings .020
Second rings .022
Main bearings .0018
Rods .0016
Main and rod bearings are Acl
Darton wet sleeves
Gsc s2 cams
Efr 8374 turbo kit
Fic 2150 injectors
4 bar map sensor
Engine specs are
Top rings .020
Second rings .022
Main bearings .0018
Rods .0016
I can't comment on the bearing clearance but you may want to open the rings and PTW up .If your budget allows I would do a carrilo since its 100grams lighter then the turbo tuff rod in a 4g63 at least.
Also, low compression will be easier on things and allow more timing to be used to keep egt down. I'd shoot for 9:1
